tach output wire
Old 10-02-2008, 08:53 AM
bgblockelcamino's Avatar
Default tach output wire
i know this has been gone over before
i have 03chevy express2500 wire harness.
do i tap right into harness for the tachometer?
also read somewhere that you can change parameters in HPtuners for tach output. to switch over to v8 output instead of usual 4cyl.
i am trying to retain my factory tachometer in my swapped 86 el camino
thanks
Old 10-02-2008, 10:20 AM
loweredd's Avatar
Do you have a pinout of your computer connectors?
I know on my 98 harness, there is a wire from the computer that is output signal to dash tach.
Old 10-02-2008, 02:05 PM
Steve VanS's Avatar
We had our '2000 PCM re-flashed by Wait4MePerformance to put out a tach signal compatible with a 6-cyl tach in our swap. Wait4Me also fixed up other things we needed / did not need. Works flawlessly.
See:
http://forums.bimmerforums.com/forum...d.php?t=699289
For our swap: LS1 & T56 into 1986 BMW E30
Old 10-02-2008, 10:18 PM
sawzall wielding director
G-Body's Avatar
It is possible to do, you do have to change the tach output with HPT or EFILive7.
The wire that you are looking for is a solid white wire in pin k of c100.
Quick Reply: tach output wire
