v6 to v8
i knew the harness would be diff. i looking at diff in buying a lt1 or buying a cheap v6 rolling chassie and doing the conversion. id buy a new bmr kmember, the trans are the same
you really would be better off buying a v8 roller...so you have the v8 suspension and the posi rear...the k member is also different, not just the mounts! and mae sure you do a harness for the year of the car or you will have big problems. dont just go OBDI with OBDI make sure it is actually the same year harness as the car...if not send it to speartech and he will set you up good on that...hit me up if you have any ?s.. ive done what you want to do so i know the process...
