PSI on motor
Old 10-02-2008, 05:03 PM
sslateron's Avatar
Default PSI on motor
On a C6 Corvette, STS says its safe to run 10 PSI of boost. That seems like a lot. If properly tuned is it safe?
Old 10-02-2008, 06:45 PM
EPP
EPP's Avatar
I don't like to see more than 8 psi unless methanol is used along with it. Bob
Old 10-02-2008, 08:54 PM
lt170chevelle's Avatar
i dont see why not...considering the ls1 is much stronger than the lt1...and mine is doing great with 10
Old 10-02-2008, 09:51 PM
otherwhitemeat's Avatar
How is it stronger???? iron block vs. alum. block.......5 bolts per head vs. 4 on the Ls1.......the ls1's heads flow better but enlighten me on how you think it's stronger....
Old 10-03-2008, 03:50 PM
sslateron's Avatar
I'm sure they wouldn't allow 10 PSI without through testing. On the product info/dyno they have 5 and 10 psi.
Old 10-03-2008, 03:55 PM
Street Legal's Avatar
well 10 PSI would be fine and wont cause a problem,but run methanol with it just to be on the safe side
i ran a D1SC 11PSI on stock LS2 and had no problems ,but i used methanol with it
Old 10-03-2008, 04:03 PM
Otto-813's Avatar
Tuning is everything.....
Old 10-04-2008, 10:27 AM
EPP
EPP's Avatar
Yes it is, but if you happen to get one tank of slightly watered down gas things can go boom. Back in high school I had a buddy who worked at a gas station who was directed by the owner to stick the water hose in the tanks to water the gas down so he could make more profit. Bob
Old 10-04-2008, 10:42 AM
oh yeah..my mistake..forgot about the aluminum blocks...i was thinking of the vortec motors with the iron blocks...i do know they are much stronger than the lt1's old school style bottom end
