TPS code and high idle???
I just changed my throttle cable on my car because I was running into problems with the cruise control switch getting stuck causing my car to not go 100% WOT. SO I ordered a new cable from the dealership that is strait from peddle to throttle body. Got everything installed and now when I give it a 100% WOT it sometimes throws an error code that the TPS is getting low voltage and high voltage. It also throws a high idle speed code. I clear the code with HP tuners and it comes right back when I go WOT. What should the TPS be set at with just vehicle power? I was getting feedback that it needs to be around 5-6% then off course when you floor it, it should be at 100% Is that the way to fix that service light? What about the high idle speed? Remember it doesn't idle high, just when it is at WOT, the computer says it is.
Thanks
Thanks
