LT1 Fuel Injector "Firing Order?"
We had one person pull the fuel injectors off to remove the intake manifold... and a couple of weeks later we have someone else installing everything..
Is there a way to figure out which wire goes to which injector?
We tried finding the "longest wire" and "shortest wire" but no luck...
And now that it ran for a few mins like that, it wont start, almost like battery is dead... so we hooked a charger up to it and same thing...
Im stuck on this car...
re
the injector clips should have a number on them 1-8 place corresponding number on the injecter above cylinder. for example the driver side front of the car is 1-3-5-7 to the rear of the driver side. the pass side is 2-4-6-8-
Well I guess it is batch fire bc its running now, without us moving and injector wires... but we found that the fuel pressure regulator wasnt adjust correctly, bc we started messing with it and it started to actually run.. But just not like it should...
How many PSI does an LT1 need? Its an (LT4 top end package)
BTW, its an Aeromotive regulator...
