Conversions & Hybrids - New Project: 6.0l/4L80E Turbo Notch Stang
cjmatt
10-03-2008, 02:18 PM
Well last night I went out and picked up a clean 92 notchback roller. Ive got a swapped lq4/4l80e turboed grand national that will be used as the donor car. Plan is to hopefully swap everything in without too many hitches. I am hoping to use the AJE LS1 K-member as well as their th400 trans x-member and get everything bolted in.
Do the th400 and 4l80e mounts line up though? havent been able to find any good information on the subject. I am also going to have to fab up a turbo hot side crossover and charge pipe. car should move quite nicely!!!
Any advice will be greatly appreciated
djquik88
10-03-2008, 03:27 PM
Sounds like fun! Where are you from?
Mike
MasterMindMotorsport
10-03-2008, 05:44 PM
should be sick
cjmatt
10-03-2008, 08:59 PM
detroit born and raised
dmracing
10-04-2008, 01:20 PM
Im doing the same swap 6.0 liter, 88mm turbo, and 400 using Aje kmember and trans mount. Im also in the Detroit area.
dmracing
10-05-2008, 02:38 PM
Where about detroit are you at?
cjmatt
02-19-2009, 09:24 AM
Bump, swap was on hold for a while, but im getting back into it. Anyone got any recommendations? Im waiting for team z motorsports here in MI to finish up their design on an LS swap K member, hope its done soon
ryanvv355
02-20-2009, 12:05 PM
Nothing like Michigan Muscle..
Good luck with the swap
MaxxMitchell
02-20-2009, 01:26 PM
I think they are close, but if you can weld well enough to build a hotside for the turbo, extending the cross member will be pretty easy. I would look at making your own crossmember from scratch vs buying one, or modify the stock one to work.
What turbo are you running? Your right, the car should feel pretty light on its feet.
cjmatt
02-23-2009, 10:34 AM
Umm, well I found a aje Kmember and all suspension stuff for the front end for a reasonable price, so I got it. But it doesnt have any motor mounts, So ive gotta either go with a motor plate setup, or get a set of the mounts from AJE and weld em on myself.
Im using one of those cheap Diesel Borg Warner S400 series turbos, 1.30 A/R with a 75mm inducer. The car runs very well currently in the Regal, very torquey, moves good from a roll. It should be very fun with 1100 lbs off of it.
Slow6.0.
02-24-2009, 02:20 AM
Good luck with the build. I did a turbo 6.0 notch w/ a manual.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
