Gear help
Old 10-03-2008, 08:14 PM
Blackhawk777's Avatar
Default Gear help
So I had a set of 3.73s installed, did the speedo correction and everything else, but ever since the install the shifting at normal driving and downshifting from a slow roll hasn't been right at all. It goes through second gear really fast at normal driving, and almost feels like the tranny is slipping when you put light pressure on the gas pedal at a slow roll. Could this be a tune/gears issue or is it a tranny issue?? Any help would be appreciated.
Old 10-03-2008, 09:33 PM
koolaid_kid's Avatar
When you say you did the speedo correction, do you mean you reflashed the PCM with the new gear ratio?
Old 10-03-2008, 09:41 PM
Yes the pcm was reflashed to the 3.73 ratio.
Old 10-05-2008, 07:14 PM
SS1875's Avatar
Possibly a converter issue or maybe you need to adjust you shift points.
Old 10-05-2008, 11:34 PM
Elliott's94Z's Avatar
This isn't going to fix your speedo from being off. Your still going to running high mph wise and be off
Old 10-05-2008, 11:38 PM
jsteele90's Avatar
shift points need to be adjusted,
Old 10-06-2008, 01:05 PM
How should I go about adjusting this? All I have is a handheld tuner *hypercrap*, and I don't really have access to any tuning program.
