Procharger Race Valve (open) question...
Old 10-04-2008, 10:02 AM
chevelle3232's Avatar
Default Procharger Race Valve (open) question...
So, I just got in and started installing a D-1SC Twin Hi-Flow Procharger on my 1996 Z28 camaro! Well, I got the Open Race Valve with Steel and was wondering if anyone could help me out on were to put it and mount it?! My thoughts were in the exact same spot but to cut and weld everything on but don't want to jump to it and mess something up!
Old 10-04-2008, 10:23 AM
EPP
EPP's Avatar
You can mount wherever you can find a location suitable. Bob
Old 10-04-2008, 10:24 AM
conan's Avatar
I put my race valve in the Y pipe that comes off the blower outlet. This way there is no supercharged air going through the small twin intercoolers untill your engine wants it.
Old 10-04-2008, 10:26 AM
I was looking at the picture of the twin flow set up, where did it end up getting mounted on that car?
Old 10-04-2008, 11:27 AM
helicoil's Avatar
I mounted my Tial here.
Attached Thumbnails Procharger Race Valve (open) question...-ls2-procharged-camaro-2-025.jpg   Procharger Race Valve (open) question...-ls2-procharged-camaro-2-024.jpg   Procharger Race Valve (open) question...-ls2-procharged-camaro-2-022.jpg
Old 10-04-2008, 11:37 AM
AFASTYZFR1's Avatar
Old 10-04-2008, 01:23 PM
N4cer's Avatar
Man, you guys have good valves. Mine is a little small thing. I haven't installed my kit yet, so should I change?
Old 10-04-2008, 03:36 PM
conan's Avatar
Its the race bypass for 8+ pounds of boost. how much boost are you going to run?
Here's mine in the y pipe. http://mycarpics.shutterfly.com/104
Old 10-04-2008, 05:55 PM
AFASTYZFR1's Avatar
those pipes hang down way to low
Old 10-04-2008, 06:02 PM
N4cer's Avatar
I'm sure I'll eventually go to/past 8lbs. Will this valve you guys have work on less than 8lbs also?
Old 10-04-2008, 09:08 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
On a LT1 car the MAF is on the inlet side of the blower. This will not work with an open bypass valve as the MAF will measure the air being vented messing up the fuel curve.
To run an open valve, you need to put the MAF in the pressure side between the blower & intake with the bypass valve before the MAF sensor.
Old 10-04-2008, 09:19 PM
conan's Avatar
Tell me about it. That's the one thing I havent liked about this kit since I put it in. Going to be making some of my own plumbing this winter to tuck every thing up it the car.
Old 10-04-2008, 11:27 PM
AFASTYZFR1's Avatar
I have same kit and mine is not even close to being that low.........you might need to clock blower some and re-position all the hoses ......... I will get you a pic tom
Old 10-05-2008, 09:07 AM
conan's Avatar
Thanks
Old 10-05-2008, 10:03 AM
Thank you guys for all the help and ideas! I got it mounted up and the whole procharger on! Now just need to get it tuned, and that leads to another problem! Anyone know a good place to go in Colorado for Lt1 Tuning?!
Old 10-05-2008, 01:31 PM
I_Need_Land's Avatar
quick Q. would the valve (open) be louder at idle / low rpm cruise than the closed one? i happen to like that loud whine noise it makes and would love to make it louder.
Old 10-05-2008, 02:43 PM
conan's Avatar
I live in park city UT and we have no tuners in the area either. I've searched for a tuner and las vegas is the closest for me. I looked for ones in colorado too.. not much luck. I'm going to trailor my car down after i get my dual fuel pumps put in. If you want I can send you a pm tomorow with the name's and #'s of the two shops I found... Its in my office at work.
Old 10-05-2008, 02:47 PM
conan's Avatar
The bypass valve is always open untill you go wide open throttle. When the throttle plate closes the supercharged air has to go some where and thats what the bypass is for. If you have a closed bypass you would blow a hose, crack the plenium ect... bad things.
Old 10-05-2008, 03:06 PM
i guess i was reading it wrong but when i read open or closed i was thinking in terms of either open to atmosphere or closed (ie recirculate like the stock setup)..
Old 10-05-2008, 04:17 PM
Yeah, that would be great! I have been to to many shops that don't get it done and get mess around to much! But if anyone else knows of any feel free to let me know!
Quick Reply: Procharger Race Valve (open) question...
