strano / koni ..pics
Old 10-04-2008, 01:11 PM
jdrummer's Avatar
Default strano / koni ..pics
just took a bunch of pics or my new strano koni set up ...used to run sportlines and stock shocks....new ride high and handling ....mint here is my f quick ...check them out .. o and anyone who take a look ...let me know your thoughs on my next mod ...cww 505a's 19 or 18 ???
http://www.fquick.com/jdrummer18
Old 10-04-2008, 01:37 PM
TXws6's Avatar
damn that looks perfect! I would go with 18x10F and 18x11R CCWs
Old 10-04-2008, 01:57 PM
DarkhorSe_SS's Avatar
rears could use the hose mod... looks good tho!
Old 10-04-2008, 09:05 PM
Dex
Dex's Avatar
Please dont do that
looks good
Old 10-04-2008, 09:10 PM
Originally Posted by Dex
Please dont do that
looks good
dude you gtfo
you don't like my suggestion move the fk on..
Old 10-04-2008, 09:17 PM
bobbyd's Avatar
dude you gtfo
hey how do you like your pro kits? how do they handle in the roads in the SA?
also where did u get ur tt2's powder coated and how much?
Old 10-04-2008, 10:08 PM
tillery's Avatar
Dont do the Hose mod with Stranos. I speak from experiance. And the person from S.A. STFU! I know you cant be running on anything to low there. S.A. has some good streets. Yea I am from around there to and had a dropped F body and drug my car almost everywhere. I hated sportlines. Got strano rears with QA1s with no isolator and it sucked. My 12 bolt was pretty much ridding on the gas tank.
Old 10-04-2008, 10:12 PM
02Z28LS1's Avatar
the fronts actually look a little lower than they should....do you have the koni's up front set on the upper or lower spring perch? if it's on the lower perch, i'd move it back to the upper asap....even Sam Strano recommends against running the lower perch with lowering springs, since there's not enough travel for the shocks to do their job properly, and they can possibly even be damaged as a result.
other than that, it looks really good, tho.
as for the wheels, i'd stick with 18" wheels personally.
Old 10-04-2008, 10:21 PM
bobbyd's Avatar
i want strano springswith my kyb's
Old 10-05-2008, 12:00 PM
jdrummer's Avatar
Default thanks
thanks guy for all the comments and advice ..i really appriciate it ....i think i def going to go with the 18's ..im going to see what perch im running on too upper or the lower ...thanks for that tip....and as far as the rear hose mod i think im goin to leve it... im lovein the ride as it is ...im not goin to mess with a good thing...
what do you guys think a 295 35 18 mich ps2 tire or the 315 30 18 ps2 tire ??? cant decide ....i want the perfect look ...just dont know ..lol any help would be greatly appriciated ....thanks again for all the comments
Old 10-05-2008, 04:01 PM
99Bluz28's Avatar
Lightbulb
I'm really sure by looking at your pictures that the koni SAs are on the lower perch. That's why the rear ride height looks high.
Still, it looks really good though!
295s, no mods at all required w/correct offset, less expensive and easier to find; just plug N play!
Old 10-10-2008, 05:00 PM
Dex
Dex's Avatar
dude you gtfo
Dont cry its only the internet panzy
Old 10-10-2008, 05:44 PM
SOMbitch's Avatar
Perfect!!! Great!!
Quick Reply: strano / koni ..pics
