rear rims too big, need help
i recently purchased a set of 19" zo6 rims off of an 07 and the back rims are 12" wide with a 325 series tire. what can i do to get these hogs under my fenders? local fbody man says i can do some minor bending and cutting, and replace a torque arm looking thing for a smaller in width aftermarket one to make a little bit more room, i just dont want to tear up these expensive tires.
UMI Double Adjustable LCA's with offset spacers
or if you already have tubular UMI LCA's with rod ends on both ends (or any other tubular LCA with QA1 XM Series ¾” rod ends), you can get the spacers separately here
