lca vs relo bracket
Old 10-04-2008, 04:43 PM
shaolink9's Avatar
Default lca vs relo bracket
which will help 60 foot more
Old 10-05-2008, 08:57 AM
kidcamaro98's Avatar
both together.
Old 10-05-2008, 12:21 PM
gyrene2003's Avatar
and what which is the most poular brand of the big ones?
Old 10-05-2008, 09:47 PM
02Z28LS1's Avatar
BMR and UMI are both top-notch brands for suspension parts, and both of them are board sponsors
i personally have UMI LCA's & Relocation brackets (among other parts from them), and they're all holding up really well
Old 10-05-2008, 09:53 PM
shaolink9's Avatar
ok both are not an option im sneaking this under my dads nose so only one
Old 10-05-2008, 09:57 PM
sweetbmxrider's Avatar
how many miles on them? spohn makes great lca's too. is there anything suspension wise done to the car?
Old 10-05-2008, 10:36 PM
Grn4fbody's Avatar
Well does your car wheel hop? If so LCA's will fix that.
I say the brackets,and if your cars lowered, deff go with the brackets.
Old 10-06-2008, 12:13 AM
SuperSlow02's Avatar
brackets..
Old 10-06-2008, 12:33 AM
shaolink9's Avatar
no
only during burn outs....atleast that when i notice
Old 10-06-2008, 01:32 AM
jsteele90's Avatar
if your lowered get the brackets if not get the lcas
Old 10-06-2008, 01:33 AM
jsteele90's Avatar
but i would just get both off of ls1tech classifieds for cheap if your trying to hide it from your dad
Old 10-06-2008, 02:46 AM
hpjunky98's Avatar
Get LCA brackets and 1LE bushings if you want to save some $$$
Old 10-07-2008, 01:04 AM
02Z28LS1's Avatar
what does hiding it from your dad have to do with anything?
if you're talking about the price of the parts and trying to hide where the money went, just save up a little longer and get both.....just exercise some patience.
and like jsteele90 said, you can also just buy both of the parts used from someone else and save some money, too
Old 10-07-2008, 08:47 AM
mad_steve's Avatar
Just in case you want another option, we carry offset adjustable LCA's. They're made of chromoly and have aircraft grade rodends. We also sell BMR's LCA relocates. If you're interested, give me a call at the shop. I'll get you prices on everything. The phone number is in my sig.
Old 10-07-2008, 09:20 AM
UMI Performance's Avatar
Hello,
We offer both weld in and bolt in relocation brackets as well as a variety of control arm options. I pasted some links below with the information on each one the products.. we can set you up with both items for around $200.00.
Control Arms- http://www.umiperformance.com/produc...ategory_id=119
Relocation Brackets- http://www.umiperformance.com/produc...ategory_id=125
If you have any questions please ask. Thank you!
Ryan
Old 10-08-2008, 08:27 AM
shaolink9's Avatar
what is the advantage adj lca?
Old 10-08-2008, 08:34 AM
Adjustable lower control arms allow you to move the rear end back or forward.. this is usually done to gain tire clearance when running a larger tire. We also suggest to use adjustable control arms when installing most aftermarket rear ends... most aftermarket rear ends do not sit centered in the wheel well and adjusting the control arm length will allow you to center the rear end.
If the adjustable control arms have spherical bearing rod ends they have a few other advantages. Rod ends allow the suspension to travel and move freely where as solid bushings or polyurethane bushings can bind it. Also rod ends offer a sold bushing for drag racing and eliminate deflection found in rubber or polyurethane bushings.
If I can help anymore please ask. Thank you!
Ryan
