Getting 1.6 rr and springs need advise.
going to get some 1.6 rr, need to know what kind are the best. I have a stock cam right now in it. If i were ever going to put a cam in it i would only go to the lt4 cam. let me know what to get. Also what springs should i get with it? Thanks Calvin
dont get an lt4 cam, nothing but disappointment IMO. i mean, if you want to spend all that time and money just to run low 13's thats fine though. go with a cc503, great cam for stock bottom end. as far as springs, i ran the comp 918 beehives and never had a prob
hopefully you choose a better cam than the Lt4 hot cam...
generally i like to have more spring than my cam requires so honestly there is not a true answer to your question however if you were to call AI or Lloyd Elliot i am more than positive either will guide you to a cam/spring that will compliment your mods...
im not set on that cam, just that i drive this car everyday, and beat on it. i really dont want to put a cam in it. trying to run low 12 with bolt ons. What my question is, what is the best 1.6 rr to put on with spring
Check out the Cam Sticky.
