Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
05 C6 M6 Steering Column Locked, HELP !
Old 10-05-2008, 05:07 PM
AlexLs1's Avatar
Default 05 C6 M6 Steering Column Locked, HELP !
You go to start the car and it turns over just doesn't start, then on the cluster "Service Column Lock" appears.
Does this or can this only be solved/fixed at the dealership or is there some way that I can fix the problem in my drive way.
Thank you any responses ahead of time.
Old 10-05-2008, 05:21 PM
AlexLs1's Avatar
I've tried thrashing the wheel back and forth turning the ignition on and off at the same time, it does not want to budge.
Looks like I'am taking this thing to the dealer, unless anyone else has a better method/solution to this problem.
Old 10-05-2008, 06:49 PM
1SLO6's Avatar
same problem with the C5's.... its gonna have to go to the dealer...
Old 10-05-2008, 09:36 PM
Cole Train's Avatar
no bypass on the C6's yet?
Old 10-05-2008, 09:38 PM
KyleLs1's Avatar
it will either need re programming or a new module... off to the stealership you go
Quick Reply: 05 C6 M6 Steering Column Locked, HELP !
