More 230/236 cam only results
Old 10-05-2008, 06:15 PM
Chuckels's Avatar
Default More 230/236 cam only results
I'm creeping up on those 11sec timeslips.
60'-1.68
1/8- 7.69
MPH-90.3
1/4-12.05
MPH- 114.5
I launched around 5200 rpm.
Cam-230/236 .545 .555 lift 112lsa
EWP, Moser 12bolt with 4.11's, Jet Hot LT's ORY w/cut out, K&N intake, march underdrive pulley, crane 1.6 rr's QA1 R's up front, sfc's, lca's, rear sway bar. I also run on bogart D-10's ..I only have removed the ac, front sway bar, and spare tire and jack. The whole interior is in the car.
Old 10-05-2008, 06:17 PM
AChotrod's Avatar
bad ***! No port work?
I have a similar set up goin in but LE2 heads.
Old 10-05-2008, 06:20 PM
Chuckels's Avatar
Heads have never been off the car.
Old 10-05-2008, 06:27 PM
registered user
ScreaminRedZ's Avatar
Damn good run! What tires do you run at the track?
Old 10-05-2008, 06:53 PM
Chuckels's Avatar
M/T ET Streets 26x10.5 on 15x10 rim
Old 10-05-2008, 07:26 PM
Goat2NV's Avatar
Great pass!! What track were you at?
Old 10-05-2008, 07:28 PM
Chuckels's Avatar
Capitol Raceway
Old 10-05-2008, 07:53 PM
street demon2k3's Avatar
A little more suspension tweaks would bring that 60ft down substantially which should put you in the 11's for sure. Good luck!!!!
Old 10-06-2008, 08:23 AM
IllusionalTA's Avatar
You got that chuckels'!!!.. Good luck in the quest for the 11's.. There is def. some more hp left in the air alone...
Old 10-06-2008, 10:11 AM
registered user
Chuckels, is that a radial or bias ply tire?
You'll get your 11's for sure!
Old 10-06-2008, 04:02 PM
lt1 power's Avatar
i have this cam with stock ported heads and run 7.53 in the 1/8 with a 1.57 60ft and thats still with stock 3.23 gears so that tells you the potential of this cam hopin for high 10's on the spray.
Old 10-06-2008, 05:08 PM
LS1 SPEED's Avatar
nice results
work on the 60ft and you are golden
Old 10-06-2008, 05:28 PM
355z28's Avatar
impressive. hows the drivability of that cam? who is making it?
Old 10-06-2008, 06:35 PM
nonosvt's Avatar
Im running the 230-236 with XFI lobes. My times are about the same as yours but i MPH a little more. Nice runs
Old 10-06-2008, 06:38 PM
gotjuice?'s Avatar
60'-1.68
1/8- 7.69
MPH-90.3
1/4-12.05
MPH- 114.5
man,thats very nice congrats
Old 10-06-2008, 07:46 PM
GMRL's Avatar
Ive had my eye on that cam as well, what RPM did you shift at?
Old 10-06-2008, 08:06 PM
Chuckels's Avatar
Bias ply tire.
This is an older grind by comp its on the XE lobe. Its basicly the 503 but with more duration.
My shift light is set at 6100 rpm, so I guess I probably shift about 6300 rpm. I wanted to raise my shift point but I forgot.
I think the cam is very streetable. My car is not a daily driver so its street manners really dont matter so much. Its got minimal cam surge at low speeds but it does have some. I've never driven any other cammed LT1 so I dont have a comparison. If you have specific questions about drivabilty I'll try to answer them. I also think that they dyno tune really helps with that over just a mail order.
Old 10-09-2008, 04:42 PM
big dave's Avatar
Hell of a pass there Charlie. The one time I didn't mind being beaten by an lt1.
Old 10-09-2008, 07:08 PM
95maroz28's Avatar
nice times man. what springs you using with it? im waiting to install that same cam. you had it on the dyno?
Old 10-09-2008, 07:14 PM
HoLLo's Avatar
Interesting. Would you recommend this cam over the 503 FULLY CONSIDERING a daily driver car?
Quick Reply: More 230/236 cam only results
