93 Z28 Guts In A V6 Car...
Old 10-05-2008, 10:00 PM
razorguy's Avatar
Default 93 Z28 Guts In A V6 Car...
Okay, so here is my situation.......
A couple months ago my car got hit while parked when I was asleep and the guy ran, well now my car is fucked. The whole rear needs to be replaced (hatch, bumper, sail panel, tail lights), and the frame is bent above the exhaust and behind the tail lights. I found a potential V6 car for cheap that is basically just at its end of the road as far as being mechanically sound.. It's a 5 speed, and my car is a 6 speed, so how hard would the swap be in that aspect?
Since it's all going to need swapped, I don't think it will matter that I have a speed density '93 and this is potentially going into a '94 V6. My main concern is how hard it will be to get the wiring harness to work? Can someone link me to the shop that reworks them for your application? That seems like the easiest thing to do..
Or would it just be easier to do all the body work on my Z28 since I'll have a donor car?
Thanks for any input.
Old 10-05-2008, 11:19 PM
LT1
LT1's Avatar
I think speartech is the place you were looking for?
http://www.speartech.com/
If you do this type of swap you'll have to modfie the fuel system, fuel line and replace the fuel pump assembly ect.
I think the clutch pedal has to be modfied on the V6 car.
Quick Reply: 93 Z28 Guts In A V6 Car...
