venom ws7
10-05-2008, 11:33 PM
O.K How much do you guys think its worth.
Info
01 Yellow C5 ZO6 with less than 33k miles clean No problems at all.
Engine:
LS6 Block.
Stock cranckshaft.
Diamond Pistons, Pistons Rings.
Compstar Connecting Rods.
Comp R Lifter.
Dual Timing chain.
Pushrods.
MTI Stg 2.5 317 Heads with Dual springs Kit.
MTI Stealth II Cam.
Ported LS6 Oil pump.
ARP everything.
with new gaskets.
8:5.1 Compresstion.
Transmisstion + Rearend:
Stock ZO6 Trans.
Exedy Twin Disc clutch.
Almunium Flywheel.
Stock Rear with 3.42.
Induction:
STS Twin Turbo.
FMIC.
60lbs Injectors.
Twin Walbro 255 Fuel pumps (in tank)
The car looks stock from the outside exept for MCM Hood the interoir is clean with Yellow and black seats.
The car made 701rwhp 669rwtq with 14psi still have a couple of more PSI and work with the tune :devil::devil:
Ran 11.3@131mph with Hoosier 295-35-18 with soft launch so low 10s shouldnt be a problem with high boost.
Brand new tires Michelin all around.
BTW The car is overseas but I just want to know what is the good price for it???
http://i112.photobucket.com/albums/n181/venomws6/01%20ZO6%20TT/DSC01207.jpg
http://i112.photobucket.com/albums/n181/venomws6/01%20ZO6%20TT/scan0001.jpg
Info
Engine:
LS6 Block.
Stock cranckshaft.
Comp R Lifter.
Dual Timing chain.
Pushrods.
MTI Stealth II Cam.
ARP everything.
with new gaskets.
8:5.1 Compresstion.
Stock ZO6 Trans.
Almunium Flywheel.
Induction:
STS Twin Turbo.
FMIC.
60lbs Injectors.
