Dyno Guesses & Bench Racing Forum - Can I take a c5 with these mods
Swift_01_z-28
10-06-2008, 02:07 AM
I am planning on adding to my mods that I have already a set of motive 3.42s, pacesetter lts and the ory and a tune hopefully from texas speed. Do you think that would be enough? I really want to get it in the twelves, I am hoping those mods get me there.
unit213
10-06-2008, 05:54 AM
Some tires would help out tremendously. Get yourself some drag radials and 12's will be there for you.
Will that be enough to take a C5? It depends on the particular C5 and the driver.
Those mods will give you enough to beat some stock C5's.
Dan Stewart
10-07-2008, 10:32 PM
Agreed, tires = 12's
As for vettes.....
iffy.....dependent on other driver.....and even bigger "if" from highway speeds
aerodynamics and weight are against you there
Patman
10-08-2008, 07:28 PM
You should be pretty close, but keep in mind it doesn't take much for a C5 to run in the 12s (see my sig)
Damian
10-08-2008, 08:33 PM
An A4 C5, yes you should be able to win.
M6, no. He'll pull past you (assuming he can drive) after about 70 mph.
Swift_01_z-28
10-08-2008, 09:00 PM
I am thinking from what I am reading, that I am gonna have to cam and stall my car to get it where I want it.
Patman
10-09-2008, 07:21 PM
I have found most C5 owners don't know how to drive a stick very well. I usually beat M6 C5s by 3-4 tenths at the track with my A4.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
