after i put my tr224 cam in
Re: after i put my tr224 cam in
a4 or M6 vette??
you could turn the TB set screw a turn or so and that would help a little. Then you can turn it back when you go to tune the car
the car just wants more air at idle, or a higher idle... dynotune will fix it though so dont worry. You may have a slight stall or sruge every once and a while still though
Vettes don't have a throttle body set screw. Give the computer some time to learn the cam. If that doesnt fix it, its time for a tune. Even a mail order program will probably fix that issue...doesn't have to be on a dyno.
When I put in the TR224 112lsa in my '98 vette, the idle was rough but it didn't stall at all. After driving around for a while it started to stall. Turns out I melted one of my MSD wires on the header so I was getting misfires.
I would check your wires to make sure they are not touching the headers. If they seem OK, either drive around and have it learn itself, or get it tuned.
