Disable Stabilitrak and TCS in GXP
Old 10-06-2008, 02:54 PM
texasGXP08's Avatar
Default Disable Stabilitrak and TCS in GXP
This may be common knowledge to a lot of you out there but I happened upon this by accident. I found that simply pressing the TCS button in our cars disables the Traction Control System, as it should.
However when the system was on and I pressed AND HELD the TCS button down, I received 2 prompts on the HUD / Computer Screen. First one says "Stability Control Off", and the car chimes, immediately following that prompt the car shows the regular "Traction Control Off" message. I haven't had a chance to drive the car without traffic so I am not sure what the difference in handling / braking is. Has anyone else messed with this?
Old 10-06-2008, 04:04 PM
Resonance's Avatar
Yep...hold it down for 7 seconds to disable both =D Works well in winter, I hate trying to go around a corner in the snow with TC off and then the damn Stabilitrack kicks in.
Old 10-06-2008, 04:57 PM
07gxpgray's Avatar
i did not know that.....i am too wondering what the difference would be.
Old 10-06-2008, 06:45 PM
texasGXP08's Avatar
OKAY, I had some fun on my lunch today. I found with both the stabilitrak and TCS disable the car definitely accelerates in turns a lot better. For instance, I made a left at an intersection from a red light stop. Typically, even with the TCS off, the throttle would cut back so that the tires wouldn't spin in a turn. With both disabled, the GXP powered through the turn a lot more to my liking, albeit, spinning the whole way....
Old 10-06-2008, 06:56 PM
Da0neEnigma's Avatar
can you tell a big difference when disabling stability track?
Old 10-06-2008, 07:01 PM
cherrygxp's Avatar
i only disable it for racing
Old 10-06-2008, 07:06 PM
texasGXP08's Avatar
I haven't done any aggressive braking or steering with it off yet, but I found the car powers through turns like it should with it disabled. I live in El Paso and it is really hard to find a street with even light traffic. This weekend, I may drive out of town a bit just to throw the car around.
Old 10-07-2008, 06:45 PM
supercatxr7's Avatar
Does this work on other LS4 models as well?
Old 10-07-2008, 07:05 PM
05CherryGXP's Avatar
If you have the button it should.
Old 10-07-2008, 07:35 PM
06WHITEMCSS's Avatar
I tried it on my '06 MCSS, no good for me!
Old 10-07-2008, 08:29 PM
07carlocrusader's Avatar
Default Tcs
I was wondering the same thing!! Because I could have sworn even with my TC off, if I take off(under hard acceleration) at a sharp turn, my crusader would still shut down on power for a split second or so and come back in for!
Old 10-07-2008, 08:53 PM
JC05GXP's Avatar
I played with it off in the snow last winter...lots of fun!! The only protection that really stays on is the differential score protection.
Old 10-07-2008, 09:17 PM
Resonance's Avatar
Thats torque management, not traction control or stabilitrack.
Old 10-07-2008, 11:11 PM
Nacho SS's Avatar
GXP only I believe.
Old 10-08-2008, 03:32 AM
williamGT's Avatar
doesn't work on my 08 GXP
Old 10-08-2008, 09:04 AM
LS1Tech Sponsor
06MonteSS's Avatar
nope, it won't... cuz we don't have stabilitrak...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old 10-08-2008, 09:06 AM
LS1Tech Sponsor
06MonteSS's Avatar
that's the "abuse mode" TM kickin in and killing your throttle... it's the "differential score protection" to save your front axles...
you don't want to be accelerating hard/spinning your tires while your wheel is turned sharply... you'll rip through your axles in no time...
__________________
Old 10-08-2008, 11:58 AM
Not true all you will do is destroy the limitedslip clutchs in the differential. When that happends all you have is the old single tire fire, peg leg burnout, one wheel squeal! Your axles, half-shafts will be fine.
Old 10-08-2008, 01:31 PM
Red03GT's Avatar
Count to at least five one-onethousands. It took me a couple tries to figure out how long I've got to hold it down.
Old 10-08-2008, 02:04 PM
LS1Tech Sponsor
06MonteSS's Avatar
aaaah, ok.. cool.. didn't know that was the case....
thx man
__________________
Quick Reply: Disable Stabilitrak and TCS in GXP
