Couple of STS Questions.
Old 10-07-2008, 02:24 AM
venom ws7's Avatar
Question Couple of STS Questions.
Guys I have STS TT ZO6 with built 346ci H/C The car have stock H-pipe
Should I do 3inch Off road X-pipe????
What is the best engine Oil I should use for a very hot wheather???
Thanks in advance.
Hussam.
Old 10-07-2008, 04:39 AM
EPP
EPP's Avatar
Hussam, I would get rid of the cats so that you don't have to worry about the cats breaking up and ruining the turbos. Synthetic oil doesn't break down like a conventional oil can, so the added heat may not make a difference. An oil cooler can make a huge difference in oil temp's, and we have seen oil coolers drop the engine temp as a result of cooler oil temps. Bob
Old 10-07-2008, 05:59 AM
venom ws7's Avatar
Thanks a lot Bob.
I will use Mobil 1 and the Cats is already removed but should remove the stock H-pipe for Bigger X-pipe??
Bob how much is the Ron Davis Radiator with oli cooler shiped to NY 11413??
Thanks,
Hussam.
Old 10-07-2008, 06:04 AM
EPP
EPP's Avatar
Originally Posted by venom ws7
Thanks a lot Bob.
Thanks,
Hussam.
An X pipe may help velocity for the rear mount turbo's, but I haven't seen any test to indicate either way.
$950.00 shipped for the radiator with the oil cooler. Thanks! Bob
