Are V6 rear discs (and rear ends for that matter) the same as LS1 cars?
Old 10-07-2008, 10:54 AM
JFon101231's Avatar
Default Are V6 rear discs (and rear ends for that matter) the same as LS1 cars?
Just like the title says, does a V6 car that has rear disc brakes have the same equipment as an LS1 car? If yes, are the entire rear ends the same (except for differences in gearing and/or LSD)?
I'm looking to pick up a set to swap onto my 3rd gen and I can't find this info, and the person I'm buying them from is a ways away and can't measure them.
Thanks
Jeff
Old 10-07-2008, 01:07 PM
LS1TECH Sponsor
Sam Strano's Avatar
98+ cars have the same rear axle and brakes. The gears in V-6's is often different, and I don't believe the LSD was standard either. But yes, it's the same rear, and the same brakes.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
Old 10-07-2008, 01:14 PM
JFon101231's Avatar
Perfect, that's what i thought, but I've been wrong before.
