LG Motorsports dyno numbers Cam/heads and LG Pro Long Tu
Old 09-11-2003, 04:29 PM
LG Motorsports's Avatar
Default LG Motorsports dyno numbers Cam/heads and LG Pro Long Tu
<B>461rwhp 419rwtq</B>
This is an 01 Z06 with our LG Long Tube headers,G5X cam package with Absolute speed 2.5 heads. Through the stock mufflers, ported throttle body, black wing filter, and pulley. No tricks with full belts etc.. the car came with a vortex rammer but we used a Blackwing to dyno so we wouldn't have to suck the hot air off the radiator. The rammer is fine when the car is moving.
I will be delivering the car to the Z06 fest at Bowling Green this weekend.
Here are a couple of the graphs from the package. Notice that the HP and TQ at 5250 rpms, where the lines cross, is about 415 tq &amp; hp. That is the bottom end that we always talk about. That means that the low end torque is up where it should be. >> "Area under the curve"<<
This was with 93 octane gas, with an agressive tune. ( I pity the guys in
Arizona with only 91 oct)
We took out 1 degree of timing and added 1% more fuel for the street, and still got 458rwhp.
** Also notice that we get roughly 340 ft pounds of torque at 3000 rpms
** Horsepower is greater than 450 from 6000 rpms to 6900 rpms
** Torque is greater than 400 rwtq from 4400 to 5800 rpms
Thanks
Lou G LG Motorsports 972-272-7753
(Larger photos at these links.) http://web.ics.purdue.edu/~lgigliot/LGM/lgm459.jpg</a> <A HREF="http://web.ics.purdue.edu/~lgigliot/LGM/lgm461.jpg" TARGET="_blank">http://web.ics.purdue.edu/~lgigliot/LGM/lgm461.jpg
[Modified by LG Motorsports, 3:57 PM 9/11/2003]
[Modified by LG Motorsports, 4:24 PM 9/11/2003]
Old 09-11-2003, 04:30 PM
Scalpel's Avatar
Default Re: LG Motorsports dyno numbers Cam/heads and LG Pro Long Tu
Good #s
Old 09-11-2003, 04:33 PM
rnr27band1's Avatar
DAMN thats impressive
Old 09-11-2003, 04:34 PM
gomer's Avatar
I want to be one of the first to say HOLY ****!! That's some damn nice power right there.
Old 09-11-2003, 06:44 PM
mike m's Avatar
now thats what im talking about.
wow now that is awesome
Old 09-11-2003, 06:48 PM
SPANKY LS1's Avatar
G5X2?
Good numbers, Shawn
Old 09-11-2003, 06:57 PM
Bowtieman4life's Avatar
sweet!
Thanks guys.
Spanky, if it was software, it would be a G5X-2.1 , It was one of the small changes we are making to the G5X-2 to see how they work. Cams are weird aren't they. A small change from a given spec will make things happen. Or not.
I want to thank Absolute speed for working with LGM to get heads that flow well not only at .600 lift, but also in the mid lift area also. The combination makes Torque throughout the rpm range.
Lou Gigliotti
LG Motorsports
972-272-7753
Old 09-11-2003, 07:00 PM
2001CamaroGuy's Avatar
I pity the guys in Arizona with only 91 oct
LOL...thanks Lou....
nice numbers
Old 09-11-2003, 07:54 PM
BurnOut's Avatar
Lou- I dig it in a big way, man... what are the numbers on your SR motor??
Old 09-11-2003, 08:20 PM
91Formula's Avatar
Sweet numbers!!!!!!
Old 09-11-2003, 08:21 PM
Shorty Director
VINCE's Avatar
That is very IMPRESSIVE!!! Keep up the good work LG..
Old 09-11-2003, 10:14 PM
AZ Power & Sound's Avatar
dammit! and I just bought a G5X2 and your changing it already! no fair!
Old 09-11-2003, 10:16 PM
Its bad enough were paying $2.31 a gallon for super... but even worse off is our super is only 91! I had to pull MAJOR timing to get my cam to run out here
Old 09-12-2003, 12:25 AM
Mike K.'s Avatar
Wow nice numbers and in a vette! That thing must haul some serious ***.
Old 09-12-2003, 02:32 AM
Nickn20's Avatar
awesome numbers! slap an electric water pump on there!
Old 09-12-2003, 07:09 AM
770Guy's Avatar
That is ABSOLUTE ly amazing.
Old 09-12-2003, 10:59 AM
LawmanSS's Avatar
Come to PA, you can get 94 for $1.99!
Old 09-12-2003, 11:08 AM
91Formula's Avatar
Or you can come to Maryland and pay $1.65 for 94 oct.
Old 09-12-2003, 02:07 PM
FASST's Avatar
I moved from PA to AZ. What a bad decission!
