Long tubes finally in, EGR question
hey guys over the weekend i finished installing my pace setter long tubes, and wow what a job! personally thats the hardest longest part change swap i have ever done on my car.
but to the meat of the question, ive already had a tune on the car prior to the long tubes and i know i am obviously going to need to go and get a re-flash, and had two questions i was wondering about:
1st - i have a 96 so it had the dual cat set up so there is 4 o2's, do the rear o2's need to be tuned out before it drives even moderately nice?
2nd - once the egr is taken off my computer (tuned out) can i just pinch the hose shut that used to connect to the manifold? i know this isnt the best idea as there are block off plates, im just low on cash since im shilling out 480 for my entire catback including the Y pipe.
thanks guys!
thanks guys!
1 - Rear o2s can set a code yes, but will not cause the car to run shitty. The fronts do that.
2. Yes, you COULD pinch the hose shut.... Just make sure you RTV it good and it seals before you go driving it. The plates are a better option, but this will work for now.
does 480 sound good from the collectors back and over the axel? (thats including tax labor and all parts, which are all mandrel bent stainless steel)
and why would i need two plates to block off the egr? i thought it was just one for the back of the intake manifold.
you need to get two plates to block off the back of the intake, then remove all of the EGR stuff including the valves, and make sure to cap the little nipples on the intake itself, and while you're in there pull out all the AIR crap.
You can make your own plates.. I've done it that way. Granted I had the Intake off at the time, but I'm sure someone has one lating around somewhere that can make a Template for you.
Also, if I'm not mistaken, you technically only have to block off the drivers side spot for the EGR Valve. That is where the Exhaust goes into the Valve and where it opens to let it into the Intake. The hold on the passenger side is where the Exhaust comes in only..
i'll let everyone know how the car runs, personally i cant wait as i can tell it already revs way faster and is more willing to rev.
before the put the long tubes on i had blown the head gasket and got a small sized cam put in and i could tell top end that the exhaust manifolds were really limiting my power. i went to a local track with a buddy who has a 2000 SLP firehawk, and with my manifolds still on he only beat me by .1 and .15 out of the two races we had. i would have him the entire way thru the 1/8th mile and he would start to edge out about the thousand foot mark and by the end would be able 3/4 car to 1-1/4 maybe a 1-1/2 ahead.
now with the long tubes its game time baby! next thing up is converter and gears!
