Stereo & Electronics - Getting rid of engine bay fuse box... nd help
InsaneAuto86
10-08-2008, 08:54 PM
I am trying to do a full wire tuck of the engine bay. As you can see in the pics below, I am only using 10% of the large engine bay fuse box. Is there any way to consolidate the parts I am using? I want to put the remaining part in the car under the dash. Thanks.
http://i91.photobucket.com/albums/k311/Insaneauto86/th_fusebox001.jpg (http://i91.photobucket.com/albums/k311/Insaneauto86/fusebox001.jpg)
http://i91.photobucket.com/albums/k311/Insaneauto86/th_fusebox002.jpg (http://i91.photobucket.com/albums/k311/Insaneauto86/fusebox002.jpg)
99345hp
10-09-2008, 05:18 AM
If its just fuses and relays you need to use you could use a universal fuse and relay box from summit. Then just run all your wires to it.
InsaneAuto86
10-09-2008, 06:48 AM
I would but the wires dont make sense. For example, when I look under the fuse box, the wire running to the fuse is not attached at the other end of the fuse. Looks like a series type of wiring, which I do not have a good understanding of.
