Some pics from the strip of EPP Formula
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
Thanks, running 9psi since the spring of '03. I plan on doing a leak down test this weekend just to see where it's at. Hope to start on a new short block soon to turn up the boost.
__________________
28 x 12.5's, I don't think I can get any bigger in there without some more mods. The back rubs a little especially when the rocks are stuck to the tires...lol.
__________________
Where are you at with your car??
__________________
OWN3D BY MY PROF!
My car is in even more pieces than last time. I've taken out 307.509699 pounds and still have quite a few more things to work on. All that's left in the car is the short block, trans, DS, and rear. I'm in the middle of painting, polishing, and porting a lot of items. Then, it's going back together. I kind of ran out of money to finish the interior and turbo setup. I'm going to be running it NA with half an interior for a while until I can afford the turbo, fuel, and safety parts.
He has strange drag brakes on the rear so there was no grinding involved.
From what I've seen it does tend to pick up a few MPH. You might want to skip the 275s and go with the 325s. They'll work, but require some more effort.
I haven't touched the interior yet and if this thing doesn't get in the 10's you will see seats and carpet laying around the pits!!
__________________
Thanks Josh! I went to put the Procharger sticker on the front spoiler a couple of weeks ago and it was a little too wide, it's going on my truck. I am going to have a local sign shop duplicate one for the car. Thanks for your help on the parts!!
Thanks, I like the pic in your sig!!
I heard rain......
I heard rain......
__________________
