Launching a M6 with nitrous off the line
How do you guys do it?
I am about to hook up my wet hit, and the only thing that is worrying me is leaving on the juice.
I have a WOT / Window switch.... I am assuming I can leave at 5k, get it hooked and then push it to the floor and do it that way... but it'd be nice to actually LAUNCH off the nitrous...
I am just afraid if I was to go WOT before the clutch dump, if the motor was to bog or anything of that sort I'd be in trouble.
Let me know how you guys do it.
I leave around 4k on spray..hold the RPMs at 4k, dump the clutch and slam the pedal to the floor. with all that TQ a higher RPM isnt as important..or youll be grabbing 2nd before you know it and probably hurt your 60ft. 4k-6.3k got me through the 60ft in 1.6sec
hmm.
I might just have to leave on the **** once I get this all hooked up.
I just blew mine last weekend on the same ****!!! Do i rebuild the 12bolt or sell it and get something stronger???
on the shot..it wont bog..least not what your use too.
02SOMWS6 how do you have your 2 step hooked up...all ive read about is nothing but problems trying to spray off the line with a 2 step
depends on the controller. My old MSD window switch took forever to boot up. My Micro Edge is ready to go damn near instantly. I would like to just have a delay built in...but it would be too set up trying to figure how much take out. I wish Lingenfelter would just put a freaking ground output on their 2 step. It took me forever to get over the fact that it dosnt turn off after the inital launch and will activate when you hit the clutch again.
O yea..if you havnt launched that high before with slicks...hitting a button when your launching is interesting to do
sorry for somewhat hijacking your thread
It's been a while since I was a 6-speed, but back in 01-02 I would bring it up to 6k and dump it on a 200 shot. One hell of a ride. I tore up 2 driveshafts and 2 tq arms. I went to a Dennys shaft and then the ring gear and mainshaft in the trans went. It your rebuilding your 12 bolts use a pro gear, it can take the his better. As for hooking it, you better not be on a 26in tire lol.
I have a Harlen 2 step (they don't make them anymore for now) whichs works with my timing tunner. The timing tunner is activated when you go WOT and trigger the micro switch. When I'm on the 2 step I hold the pedel down as far as it takes to be on the limiter so I'm not mashed to the floor trigerring the timing tunner. But my 2 step has a activation wire that is not live untill the 2 step is shut off. So I could hold it to the floor if I wanted to but sometimes all these different things hooked up scares me that 1 will fail so I try to do it as safe as possible. The timing tunner controls the delay and pulls timing for my set up . I could live with out the 2 step but I depend on that timing tunner.
