BMR does it again...
This is my second k-member that doesnt have holes in the right spot. First one had a motor mount that was off by half a hole (shifted ~ .25"). I sent it back and got a new one. This time the steering rack isnt bolting up right. I put the bolt in one hole and try and hook up the the bolt (there are two places in the front of the k-member that the steering rack bolts too), and no dice. That hole is off ~.125". I used a screw driver and tried to bend, pry, anything to get the holes to line up so i can get the second bolt in. NOPE, not happening. i need to get a big drill bit and open the hole up on my new k-member so I can get the damn bolt in. Crap like this pisses me off. I can only imagine what a disaster putting the k-member back in the car is gonna be. Lets hope they only screwed up one mounting area.
BIG THUMBS DOWN BMR, CHECK YOUR JIGS!
Originally Posted by cyphur_traq
One reason I only run Spohn/UMI.
RealQuick - Sorry to hear about the hassle. I just ordered a BMR K-member from Speed Inc so hopefully it will install okay.
Originally Posted by DrkPhx
Neither one makes a K-member so we have a limited selection. Spohn was supposed to come out with one earlier this year, bu never did (don't even think they built a prototype yet).
Originally Posted by sikws6
I am sure you have contaacted BMR about the problem right? I have had BMR products for several years(includind their k-member) and have had very few isues with fit or finish sure your putting it on right?
try a PA from finish line performance
i have a PA k-member and A-arms
install was perfect.
i also will NEVER EVER buy aanother piece from BMR after breaking a trak pak torque arm on a mid 12 second car. the tube stretched and brake... which trashed the yoke (160 gone), the drive shaft (350 gone), and what i thought was a good torque arm (415 to replace with the Spohn unit.... which looks a TON stronger and has held up to a ton of abuse).
some day ppl will learn not to buy from them
I'll be looking at the Spohn stuff from now on.
