Harris Speed Works is awesome!
To make this as short as I can, Harris Speed Works, in Warminster, PA, did the following for me.
For my 2002 Z28:
- fixed the rear pinion seal and pinion seal gasket leak;
- replaced the rear crush sleeve;
- installed Koni SA's, Strano springs, UMI weld-on LCA brackets, and UMI double-adjustable panhard rod;
- and installed the SLP lid and SSRA2 while doing back to back dyno runs (for 9 runs--3 were baseline) to see how the induction mods increased the car's horsepower and torque.
For my 2006 GTO:
- installed the Midwest front splitter
- installed the LS2 Port Works ported throttle body and AEM CAI while doing back to back dyno runs (for 9 runs--3 were baseline) to see how each induction mod affected the car.
All I can say are the following:
- Matt and Nick will answer your emails as soon as possible.
- They will give you the attention that you need so that everything you want done is followed to the dot. (This also eliminates the risk of miscommunication between them and between them and the customer.)
- They will go over the invoice for you line by line so that you understand what they exactly did.
- They're friendly.
- They're honest.
- They will pick up the phone.
- They will give you free soda.
- Their installation prices are lower than most shops.
- They will laminate all of your dyno graphs.
- They will film your dyno runs and put them on DVD.
- Their installations are high quality.
- They know what they're doing.
- They have a REALLY big and CLEAN shop in a suburban area.
- They keep their promises.
- They're reliable.
- And they will fix what other shops break.
Here are all of the related threads for the work that was performed on my Z28 and GTO by Harris Speed Works for the date range of 11/07/06-11/12/06.
Strano Lowering Springs On My 2002 Z28--BEFORE & AFTER PICS!!! 56K = die
'02 A4 Z28 w/PTB dynoes@298...after SLP lid, dynoes@303...after SSRA2, dynoes@318!
Check out the Midwest splitter on my Quicksilver GTO! 56k = die
'06 M6 GTO dynoes@351 stock..after ported TB, dynoes@359..after AEM CAI, dynos@365!
For my 2002 Z28:
For my 2006 GTO:
- They're friendly.
- They're honest.
- They're reliable.
