LS1TECH Sponsor Feedback Tell us about your sponsor transactions
UMI++++ Lots o pics (k-member, subframes, torque arm, T/A relocation bracket)
Old 11-17-2006, 12:42 PM
DVST8OR's Avatar
Thumbs up UMI++++ Lots o pics (k-member, subframes, torque arm, T/A relocation bracket)
Well I finally got some pics of all my new UMI suspension stuff installed. So I just thought that I would share.
UMI k-member :
UMI 3-point subframes :
UMI torque arm relocation kit :
pics of the whole setup :
Old 11-17-2006, 12:44 PM
lastcall190's Avatar
Pardon my negligence, but what's the advantage of an aftermarket k-member, besides looking much better than the stock one? Parts look good!
-J
Old 11-17-2006, 12:49 PM
amsterdamn's Avatar
-J
Front end weight reduction. Also, for the turbo guys there's more room to work with.
Old 11-17-2006, 12:50 PM
DVST8OR's Avatar
-J
Weight savings and its stronger than the stock piece. It makes header installs a breeze. And plus there is no huge stamped metal piece to catch every single nut, bolt, and part that you drop in the engine bay.
Old 11-17-2006, 01:43 PM
Prey4Me's Avatar
Looks awesome! Thats the same setup that I am going to put on soon. Any clearence issues with the TA relocation bracket? I'm wondering if it will clear my TSP true duals? but, I should be somewhere around your numbers on bottle, just wondering what clutch you are using?
Old 11-17-2006, 01:47 PM
Revelation Z28's Avatar
i think it caught one of my fingers when i was working on the car
once i get mine, i will take pride in dropping the oil pan
Old 11-17-2006, 03:26 PM
DVST8OR's Avatar
The exhaust is custom and made to fit around suspension. But so long as you have a transmission mounted length torque arm it will clear TSP true duals. In fact that is the test car they used at UMI. If you go to their site they have a pic showing a car with TSP true duals and the relocation kit and it clears just fine.
And I am using Spec stage 3 for clutch.
Old 11-17-2006, 03:28 PM
Thanks for the answers
Old 11-17-2006, 03:35 PM
Silver02TA's Avatar
loooks good, you have the best Camaro on here, IMO
Old 11-17-2006, 03:58 PM
ls1king000's Avatar
God I hate that too.
I really like the UMI k-member. Just wished you buy it with lowered motor mounts.
Old 11-17-2006, 05:58 PM
BlackHawk T/A's Avatar
Wouldn't that cause problems with headers that barely fit?
What about the change in driveline angle? It would move your transmission down slightly also.
Old 11-17-2006, 06:23 PM
madmo's Avatar
So will this K-member really stand up to daily driving how long have you had it on? Any problems?
Old 11-17-2006, 08:27 PM
DVST8OR's Avatar
Thanks. Awesome compliment coming from you. You truly have one of the best looking Trans Am's I have ever seen.
Brian
Old 11-17-2006, 08:29 PM
DVST8OR's Avatar
I don't daily drive my Camaro anymore, but I can assure I drive it plenty ever week and I am no slouch in the turns or in the way I drive on the street. But I have only had the k-member on for a month or so. So far so good. I haven't had a single problem.
Brian
Old 11-19-2006, 09:33 AM
UMI Performance's Avatar
Brian,
Thanks for the detailed pictures, the installation looks excellent
Thanks again,
Ryan
Old 11-20-2006, 06:49 PM
SpdFrk1990's Avatar
Would is still be alirght to jack the car up on the k-member?
Old 11-20-2006, 07:21 PM
Yes you can do that with no issues.
Thanks,
Ryan
Old 11-20-2006, 07:39 PM
SpdFrk1990's Avatar
Is the stock k-member slotted like this where you hook up the control arms?
Old 11-20-2006, 07:59 PM
Hello,
Yes the factory K-Member is also slotted where the A-Arms mount. We did however lengthen those slots an addtional 1/2" for alignment if needed.
Hope that helps!
Ryan
Old 11-20-2006, 08:20 PM
SpdFrk1990's Avatar
Sounds good looks like a nice peice.
