brand new texas speed 402, no oil presure?
Just started my 402 LS2 Texas Speed short block.MTI heads,custom cam
LS oil pump,all new stuff.Within about 30 seconds of runnig ,in my opinion the
motor did sound quit enough so i shut it off.I noticed the oil pressure was pegged all the way for the first 15-20 secs then fell alomost to 0.With a little rev it would lag to 20 psi so I pulled the timing cover & notuced that when cranking the engine there is a hole on the DS block next to the oil pump that sprays oil out after a few secons of cranking.Seems odd to me that oil is coming out.I don't like it!I've built a good few engines & have covered everything.The pickup is secure,the pickup oring is new & tight,the oil pump spacers are instelled for the double roller chain.Oil pump is LS6.The oil pan,
relief valve & oil filter are stock LS1.I hope 4,000 grand did not go by the wayside tonite.Any help at all would be great.
Praying for luck!
Praying for luck!
Originally Posted by navymitch12
is it that hole that is capped in my block?
That hole is should have a freeze plug in it and at the other end meaning the back off the block,there also should be whats called a barbell restrictor plug.If the plug up front was not there,I would also ck and make sure the one in the back is not missing also.
LSxGuy widda 9sec Mustang
The blocks come in completely bare, but thats odd that the plug is missing, all Shortblocks in the past 5-6 months have been shipping with the plugs installed, and Longblocks have always come with the plugs. Do you think the oil pressure was correct on startup? If it had high oil pressure then dropped, maybe the plug (if installed) was pushed out or not seated good and then pushed out under oil pressure. Did it come with the other plugs installed, the 3 small threaded plugs, and 1 large threaded coolant plug?
An edited copy of this will be moved to Sponsor Feedback so TSP can find it, sent them a pm so they know to address it.
Could you please post your name so they can get all paperwork ready before responding? It just helps them know which build this was.
texas speed 402
I,m going to work on my week off to pull the trans & see if the rear plugs have fallen out or were ever installed.I will contact texas speeds after i have confirmed that & will post back the response from them & bring all up to speed.Thanks for the help to all who posted,it seems that each time a
question needs to be answered the POWER OF KNOWLEDGE in this forum never ceases to amaze me.Thanks.
Glad we could get everything lined out Perry. Throw the plugs in it and fire it up!
For those watching the thread: This motor was purchased in October of last year. We did NOT start including plugs with short-blocks until the first of this year. Since we use new blocks on all of our engines, they do not come with any plugs installed whatsoever. So, you must install the oil galley plug, oil restrictor, three small coolant plugs, and one large coolant plug. At the beginning of this year, we started including these plugs in all of our engines, short- and long-blocks. We now include these plugs for this very reason. Many people, including shops, are not aware that there are plugs that should be installed in LSx blocks.
Let us know if you have any other questions or concerns.
The plugs should be in by Sat at the lastest so we will soon hear the
motor fire(with oil pressure).I'll keep everybody posted.
MY girlfriend says Texas Speed owes her 2 days of vacation.I changed our plans after the setback.Oh well.
