Crankshaft Position Sensor + Service Parking Light Errors?
Old 10-27-2008, 08:54 PM
1BADCTS's Avatar
Unhappy Crankshaft Position Sensor + Service Parking Light Errors?
My check engine light came on... The computer is throwing a code for the crankshaft position sensor --> anybody replaced this on their own or can give me a few pointers? Is it on the side closest the front bumper, or towards the firewall?
I can't figure out the "service parking lamp" message displayed on the center screen. All of my lights seem to be working fine. Any ideas?
Thanks,
Mark
Old 10-27-2008, 11:34 PM
neilownz's Avatar
what code number? did you do somethin that requires a crank relearn like change the ecm or somethin?
Old 10-28-2008, 08:10 AM
1BADCTS's Avatar
Neilownz,
The code is P0315
Well, I've been fighting a BCM issue lately that I finally resolved which was causing my power locks to not work. I'm new to the W body crowd, so I'm a little behind the curve on these cars.
FYI, not knowing what else to do I did install a same part # BCM from another car into mine for a few minutes to try and see if that was my problem while working on the locks. Stupid, maybe, but I dind't know any better. It put the car into security mode until I put my old BCM back in... which is about the same time the light came on now that I think about it.
Is there a crank re-learn procedure?
Any help is appreciated. Thanks in advance!
Mark
Old 10-28-2008, 10:13 AM
BADDLS1SS's Avatar
You can do a case learn with HPT. BTW the crank pos sensor is on the fire wall side of the engine, covered by the trans right below # 8 cyl.
Old 10-28-2008, 11:06 AM
neilownz's Avatar
the dashhawk can do it too. or you can go to the dealer i suppose they will charge like $50 depending on how they are. i would try the relearn procedure before trying to find the sensor. search for case relearn or P0315 on the forum since i suppose someone else has gone through a similar problem.
Old 10-28-2008, 12:48 PM
1BADCTS's Avatar
Ughhhhh... Called the dealer... they want $95 to do the re-learn. I'll shop around!
Thanks for the info everybody.
Mark
Quick Reply: Crankshaft Position Sensor + Service Parking Light Errors?
