Supporting engine for tranny removal
Old 12-07-2008, 01:39 PM
supercatxr7's Avatar
Default Supporting engine for tranny removal
For those of you who have removed the transmission, where did you hook chains to on the front of the motor? I bought an engine support brace to support the engine while the subframe and transmission are taken out. I see the hook/bracket on the back of the motor to connect chain to, but cannot find anything on the front. Pictures are helpful.
Thanks!
Old 12-08-2008, 07:16 AM
BADDLS1SS's Avatar
Did you get the brace that is for sure for LS4 cars? Have fun with the steering shaft too when dropping the k member and sterring rack hoses. That hard rubber boot over the steering shaft is a MF'er tohold out of the way while taking the bolt out. getting it back on is even more fun now that you will have your hand in there too.
Old 01-15-2009, 11:22 PM
WE TODD DID's Avatar
I always pull out the bolt holding the engine oil dipstick to the head, and put a longer bolt in place of it to hook to. I use a large diameter flat washer at the end of the bolt so the hook won't slide off.
Quick Reply: Supporting engine for tranny removal
