AC turning on when you start
Old 03-03-2009, 08:22 AM
mp4life23's Avatar
Default AC turning on when you start
Is there a way that you can turn this off ? Every time i start the car the ac turns on. Driving down the hwy some times i forget to turn it off and my mpg go's down
Old 03-03-2009, 08:37 AM
texasGXP08's Avatar
disconnect the wire harness from the compressor?? lol, j.k. idk...
Old 03-03-2009, 09:22 AM
cherrygxp's Avatar
im assuming you live where its cold.. The a/c help defrost the windows. Alot if time when i use my auto start it will turn on.
Old 03-03-2009, 09:37 AM
GXPolice's Avatar
Good question, mine does this most of the time as well and i can't find a way to diable it...whether using autostart or starting it manually the first thing i have to do when i get in is push that darn air-conditioning button and turn it off.
Old 03-03-2009, 09:46 AM
EmersonHart13's Avatar
Exactly.
Old 03-03-2009, 10:03 AM
Scarhead's Avatar
The only time my A/C comes on (and stays on) when I remote start is after I've turned the car off with the A/C button still engaged.
Otherwise, it will try to normalize the temp to whatever the climate control temp is set at after I turned the car off.
Old 03-03-2009, 11:08 AM
mp4life23's Avatar
The funny thing is that ive tried the turn the car off with the ac off and the darn thing still comes on after i start it up again its pretty nerve racking
Old 03-03-2009, 11:51 AM
You live in a warmer climate and therefore the car will behave differently.
Old 03-03-2009, 12:09 PM
Scarhead's Avatar
Well the past few nights it's been <40 degrees here, and my climate control is set at 60 pretty much all the time.
When I get in my car (after remote start) and turn the key, the A/C button is only engaged after I've turned the car off with it engaged. If I turn the car off with a/c off, it won't be on when I turn the key.
so...
Turn Key off with A/C off = Remote Start goes to climate control temp. Turn key to on position and A/C is off
Turn Key off with A/C on = Remote Start goes to climate control temp. Turn key to on position and A/C is on
..Not tryin to be a smart ***, just thought the paragraph I wrote was confusing.
Old 03-03-2009, 02:04 PM
No worries, I rarely get the AC on thing, but it happens occasionally. I don't understand the car's logic, something tells me there isn't any, but I assume it turns it on for a reason...
Old 03-03-2009, 05:45 PM
cherrygxp's Avatar
it automatically does it doesnt matter if you turn it off or not. it does it judging by the weather. The computer decides when its best and when its not
Old 03-03-2009, 10:07 PM
Panther427's Avatar
Dont run your controls in Auto/ IN auto it will run the AC maybe try that. i rarely run mine in auto and i have never really experianced what you guys are talking about.
