hooking subs up / Ipod adaptor for stock GM ss radio?
Anyone know were i can get an ipod adaptor and adaptor to put aftermarket subwoofers on the stock radio unit in my SS?
I plan on getting an LCD unit at the end of the summer but for now i wanna hook the subs i have into the bose system.
Ive searched around but can't find much, would appreciate the help.
For hooking the subs and and amp up to the stock head unit try PAC's AOEMGM24 interface. Its plugs into the back of your radio with a little bit of wire splicing, if you have a bit of stereo install knowledge it should be fairly easy! It is not an exact fit (at least not for my GXP, but it is easy to make it work. Follow this link for the interface:
http://www.logjamelectronics.com/pacaoemgm24.html
As for the iPod adaptor, I'm not sure if you can do both the PAC and the iPod at the same time. Some others might know better than I do, but here is a link you should check out:
http://home.comcast.net/~warren.family/XM.html
Hope this stuff helps you out!
You can get a cheap line output converter for alot less than that and just tap signal from your rear deck speakers, that's how I had my sub hooked up before swapping out the stock HU for a double DIN touchscreen unit. However, if you're eventually going to be getting a double DIN unit, which will most likely be able to directly control your ipod, I wouldn't even bother with the ipod adapter and just make due using the aux input for now.
The Amp is just for the 2 12" DVC's in the trunk, but I also have 2 pairs of Kicker KS13's that I need to have installed to spruce up the high end, and she'll be perfect.
I have one JL Audio 12" with the stock Bose system. Sounds good enough for me since I'm no audiophile. Obviously an improvement once I ditched the stock headunit for something new.
im keepin my wit da stock unit
just bought a JL audio clean sweep,it allows u to hook up 3 different aux while usin a stock head unit(paid 300)hope it helps...
A bit on the expensive side,but gotta have the best for tha whip...iwanna keep it lookin stock from the inside meanin head unit,but wanna have king kong in my trunk!!!system is half way there I already have JL clean sweap,JL 1000/1 and 450/4 amps...just need 2 get my W6 13 in sub wit custom box ported thru top speaker deck and inside speakers which will be some boston acoustics...sooo it is work in progress,hopefully by the end of summer should have everything and maybe installed...will post picks when thru...
