Blown tranny?
Blown tranny?
For any of you guys that have had your transmissions go can you describe the symptoms? just wondering when your trannys started to go what it felt like and when you actually brought it to the dealer? did you wait for it to completely go?
What symphtomps are you seeing?
Mine has not gone yet, but from what I have read on here some peoples trannys just failed to go back in gear, some had driveability issues, searching for gears, Hard shifts, slow sifts, car bucking.
There is a TSB that you can take to your dealer, they will drop the tranny oil pan and look for shavings. I'll be doing this since mine is staring to buck on the last down shift when slowing down.
I don't have access to the full text of the TSB's and could not find the one posted earlier.
A search on http://www-odi.nhtsa.dot.gov/cars/pr.../tsbsearch.cfm revealed 7 TSB related to the tranny but it does not give full text.
The search is for an 07 though.
Results : 7 | All records displayed
Make : CHEVROLET Model : MONTE CARLO Year : 2007
Manufacturer : GENERAL MOTORS CORP.
Service Bulletin Number : 4133 Date of Bulletin :
NHTSA Item Number : 10022769
Component : POWER TRAIN:AUTOMATIC TRANSMISSION
Summary :
TRANSMISSION SLIPS, WILL NOT SHIFT, SES LIGHT MAY BE ILLUMINATED. *KB
Check to Request Research. Submit below.
Service Bulletin Number : 4112 Date of Bulletin : JUL 01, 2008
NHTSA Item Number : 10023432
Summary :
SAG OR HESITATION ON ACCELERATION (NORMAL OPERATING CHARACTERISTICS). EQUIPPED W/ GASOLINE ENGINE AND AUTOMATIC TRANSMISSION. *NJ UPDATED 1/30/08. *NJ UPDATED 10/01/08. *PE
Service Bulletin Number : 08-07-30-016 Date of Bulletin : APR 01, 2008
NHTSA Item Number : 10025421
Summary :
DIAGNOSTIC INFORMATION ON MH1, MN8, MT1, M15 TRANSMISSION SLIPS, WILL NOT SHIFT OR MAY OVERHEAT, SES/MIL MAY BE ILLUMINATED, DTCS P0218, P0894 SET. *PE UPDATED 8/12/08. *PE
Service Bulletin Number : 080730002 Date of Bulletin : MAR 01, 2008
NHTSA Item Number : 10025065
Summary :
INFORMATIONAL ON 4T65-E MN7, M15 AND M76 FRONT WHEEL DRIVE AUTOMATIC TRANSMISSION VALVE BODY RECONDITIONING, DTCS P0741, P0742, P0757, P842, HARSH SHIFTS OR SLIPS. *PE
Service Bulletin Number : 08-07-30-002 Date of Bulletin : JAN 01, 2008
NHTSA Item Number : 10025561
Summary :
INFORMATION ON 4T65-E MN7, M15 AND M76 FRONT WHEEL DRIVE AUTOMATIC TRANSMISSION VALVE BODY RECONDITIONING, DTCS P0741, P0742, P0757, P842, HARSH SHIFTS OR SLIPS. *PE
Service Bulletin Number : 070730012 Date of Bulletin : OCT 01, 2007
NHTSA Item Number : 10021844
Summary :
4T65-E TRANSMISSION SLIPS, NO DRIVE/REVERSE, TCC SHUDDER, NOISE WITH TCC APPLIED. *KB UPDATED 08-15-07. *KB (DIAGNOSIS & REPLACE TRANSMISSION, IF NECESSARY). UPDATED 2/19/08. *NJ
Service Bulletin Number : 060730023 Date of Bulletin : SEP 01, 2006
NHTSA Item Number : 10020766
Summary :
4T65E TRANSMISSION 1-2 SHIFT SHUDDER AT LIGHT TO MODERATE ACCELERATION. REPLACE COMPLETE SECOND CLUTCH ASSEMBLY. *KB
Summary :
Summary :
Summary :
Summary :
Summary :
Summary :
Summary :
I might be paranoid but i dont think i am. shifts at light load and low speed seem to be harder and more noticable. shifts at wide open throttle seem to be slipping but its slight. when going into 4th the car feels like its serching for 4th. like i said its all very slight. just wondering if when theys trannys go they go and are undriveable and thats when to have it replaced or if it rarely becomes undriveable.
Does the RPM's bounce at cruise while on the highway? If so, you will need a new transmission. That was what mine was doing before it **** the bed. The best thing to do is a search and you will find quite a bit of symptoms that may be what you are experiencing. I nursed mine from 48k to 64k with a bad trans. Eventually I lost 2nd and 4th gear. These transmissions suck for a V-8 application. Sad but true...
-Mike
-Mike
