Tire Goo
Tire Goo
What's the part number for the can of GXP tire sealer goo? Been unable to locate the Bonneville GXP spare wheel/tire combo for months and have already used the sealer that comes with the GXP. Should just pick up some aftermarket stuff, but want to check to see how much the OEM sealer is first.
I figured in the case of a flat, I'd squirt the sealant in the tire, then use the stock inflator for additional psi if necessary. Yes, in Denver. My car's at Suss today for a leaking oil pan gasket, front brakes, warped cowl cover replacement, and navi system that doesn't play MP3 discs properly.
Thats great ur in denver im up in greeley. U Should join a local board. www.coloradolsx.com
Fun to go to the track with lots of people, cruise and what not. My name is panther427 on there as well.
