3 questions from a newbie
Just purchased 2006 GXP
1. transmission temperture is running about 223...is this OK
2. when starting off from a stop, even at a slow speed the rear end seems to drop into a small hole...?
3. light and sometimes loud grinding noise when backing up and turning the wheels...?
1. i called the dealer about tranny temp they said dont worry untill it hits like 260 the only time i have seen it around 230 is hen i was autocossing though on hot days thats probably pretty normal mine usually stays between 170 and 200 it will go up rapidly if you send a lot of time in one place
2. accel will make the rear end squat just how things work
3. the "grinding" that you are talking about i think is actually the abs system testing itself i believe. im not sure what you are reffering to when you say light as in lights or light noise though
Hard to help u with the 3rd one from behind the computer. Any more info on it. Exactally when it happens. Speeds, RPM, Degree u have the wheel turned. When car is cold, only does it after u been driving. ECT
