Question fellas???
Old 08-07-2009, 08:47 PM
1 CLEAN SUP3R SPORT's Avatar
Default Question fellas???
I let my car sit for a week(8 days),w/o starting it is it normal for the battery to be drained completly???
Battery was an optima red top,but upgraded to the yellow top...mind you the battery was 6 months old,any ideas,is it normal???
Old 08-07-2009, 09:10 PM
06 SS's Avatar
first off, changing from a red top to a yellow top is not an 'upgrade'. The YT is designed for low continuous load, the RT is for quick/high load applications (like starting a car). Second, get a meter on it and see if there what kind of load is on it when the car is off. It could be that your YT (remember, not designed to be good at starting a car, but more like a trolling motor on a boat), gets just weak enough over a week of slow drain to not have the oomph to spin the starter motor.
Old 08-07-2009, 09:16 PM
Mels SS's Avatar
Also check your cables that there not lose mine was and the alternator didn't charge the battery I cleaned the connections and used battery grease and tighten everything up.
all Ok!!
Old 08-07-2009, 09:22 PM
neilownz's Avatar
I think it's fairly common for there to be a bit of a parasitic leak in the system, but you could take it somewhere to have it tested.
Old 08-07-2009, 10:05 PM
mike690003's Avatar
I have a red top, and I usually have mine sit about 14 days, it starts up fine. My stock battery wasn't up to that task though. That is why I went with the red top.
Old 08-07-2009, 10:17 PM
01ws666's Avatar
My red top did the same thing a while back, same situation battery was only 6-8 months old and car was not started for 7 days but I left my radar detecter on and my I-pod plugged in and charging so I figured that was the cause...
Old 08-08-2009, 12:05 AM
Aaron_Provost's Avatar
06 SS, you're thinking of blue tops, those are for boats, yellow tops are made for cars with systems
Old 08-08-2009, 03:28 AM
StealthV8's Avatar
my car sits for weeks at a time, only use it on nice days on the weekend and this has happened once in a year. charged it up and all well for about 3 months now
Old 08-08-2009, 05:33 AM
06 SS's Avatar
thanks
Old 08-08-2009, 01:26 PM
CenTexSS's Avatar
That's what I was thinking.
Old 08-08-2009, 06:34 PM
all Ok!!
Cables are secured correctly and the ternimal are clean with those red and green pads under the battery connectors...
Do you maybe because the onstar?
That the reason why I went with the red top my stocker went bad on me...
No radar and no ipod...
Off topic what part of modesto you from???
Old 08-08-2009, 08:45 PM
neilownz's Avatar
Onstar should use the backup battery if the vehicle is off. That would be a retarded gm design, so it's possible.
Old 08-08-2009, 10:47 PM
Well I reading on another forum that there is a tsb don't remember the number but it was for 06 and 07.that the on star had to be reprogramned...
Ill see if I can find it...
Old 08-09-2009, 02:48 AM
01ws666's Avatar
Off topic what part of modesto you from???[/QUOTE]
I'm near coffee and orangeburg by Downy high, you in empire? Me and my friends have weekly car meets @ starbucks on briggs and Mchenry, you ever roll out there?
Old 08-09-2009, 12:57 PM
I'm near coffee and orangeburg by Downy high, you in empire? Me and my friends have weekly car meets @ starbucks on briggs and Mchenry, you ever roll out there?[/QUOTE]
Na,don't live in modesto any more.lived there for 2yrs,then moved back to so cal...use to stay on the west side,paradise and peggy lane...
