CV Boot leaking
CV Boot leaking
Took the gxp to the stealership to get the power steering hose fixed and they said that the cv boot was leaking. Have any of you guys heard of this? and how do you fix it?
i just did mine a few weeks ago, its leaking the grease out of the boot, if its not fixed soon the cv joint will start to make noise like a poping clicking noise
i do suspension work differently, some guys do it their way i do it my way personal choice i guess
remove the tire
remove the cailper
remove the caliper bracket
remove the rotor
the way i do it is i scribe the knuckle with my metal scribe where the strut bolts too, then i remove the 2 bolts at the knuckle
dont forget to hang the caliper with mechanics wire or a coat hanger it just can hang by the brake line
so i use a pry bar and pry gently around the inner joint its just cliped into the trans, and POP out is comes
when its out by the trans move it back to remove it from the wheel bearing
but your going to have to turn the wheel a bit to the left or right to gain acsees to the axle
then send the shaft out to be rebuilt, that cost me 30 bucks, then reverse the procsess, but when installing into the trans again the joint and wheel bearing has splines so it has to catch the splines on the bearing and inside the trans, wiggle wiggle find the correct teeth, and POP in it goes<<<thats what she said
then reverse the install, ya might need a alignment ya might not, i didnt need one just make sure you mark the knuckle
thats it BOOM DONE!!
remove the tire
remove the cailper
remove the rotor
its on the passenger side its leaking around the clamp so its not torn they said it was wasnt under the power train warranty because its a wear and tear item does that sound right
Buy a new clamp. Remove old clamp and inspect for torn boot. If not torn, clean and install new clamp. If torn remove and replace boot, or just change out axle pending price. Don't know how much they cost for your car but I have changed out cv axles for as little as 65$ each. The last boot kit I changed iirc was like $25. You can always take back the unused part.
Yeah I had a same issue a long while back. The dealer fixed it and it failed again. I just bought a new axle from Advance Auto. I saved the old one just for hahas.
