Who has the new deeper style Cold Air Inductions CAI on their Monte/Impala?
LS1Tech Sponsor
does yours touch/rest against that red wire on the starter?
also, with the ecm mounted in the bottom of the box, is your wire harness pulled tight???
thanks...
thanks...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
LS1Tech Sponsor
*bump*
__________________
LS1Tech Sponsor
this is the newer one:
http://coldairinductions.com/cart/in...roducts_id=801
and this is the older/original one:
http://cpanel3.heritagewebdesign.com...1231282651.jpg
__________________
LS1Tech Sponsor
cuz mine is on the wire - I gotta look at loosening up the bolt on the starter there and push the red wires down, cuz it's rubbing on it pretty good, may even be through that protective jacket on it already....
and my wire harness is pulled TIGHT to get that ecm swung around and put on both of those mounting posts....
hmmm....
the wiring harness must be routed differently on mine/yours...
can you do me a favor mel, and take a good close picture of your setup in that corner of the bay?? from that side of the box, so I can see how yours is situated, and where your harness is routed, how the starter wires are positioned, etc etc???
thanks man, I'd appreciate it!!
__________________
