diablo tuner
diablo tuner
so i installed my diablo tune with dod turned off...does that mean that i cannot use cruise because it would not let me do it on the highway i figured because it must have to able to go into 4cyl mode to use crusie am i right?
Correct. The diablo tune has nothing to do with the CC. However, other mechanical failure, such as a brake system issue and/or traction control will stop CC from working. I've had the diablo no-DoD installed for over a year and it has no effect on the CC.
You have any other warnings/lights on the dash?
well i tried the diablo dod on today and then the cruise worked....but my check engine light is now on?! idk unfortunatly i cannot remember for sure but am 90 percent sure that the check engine light was not on with dod off. dod off the cruise acted liked it wanted to engage or engaged for a millisec then shut off.
LS1Tech Sponsor
yeah... definitely doesn't affect the cruise control...
there aren't even any parameters available in the editable tune file that have anything to do with cruise control...
and no, the DOD does not affect the CC at all... have had it off for almost 5 years now in my car, and my cruise and everything else still works just fine...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
LS1Tech Sponsor
yeah yeah....
__________________
LS1Tech Sponsor
Displacement on Demand... same thing as Active Fuel Management... GM just changed the name...
__________________
