Track Time Compilation updated 5 MAY 2015
Old 04-01-2010, 08:11 PM
AlabamaGuy's Avatar
Default Track Time Compilation updated 5 MAY 2015
Please post your times, mods, whether you had DRs or street tires, and what vehicle it was (ISS, MCSS,GXP, or LXS). Putting it in the same format that we have them here would be awesome too! It'd make my job a lot easier.
N/A Cars:
12.558 @ 113.19, DavidGXP - 1.970 60ft 8.151 @ 89.27 1/8th TFS 205cc heads, Pat G cam, Ported LS6 intake, 3" catted exhaust, DT headers, TEP spec'd trans w/stock converter and 3.69 gears. 285/35/18 NT555R (06 GXP)
13.07 @ 107.82, Supercatxr7 - 1.935 60ft [1.8 roller rockers Ported LS4 intake, K&N CAI intake, Hoagan DP, Magnaflow exhaust kit, and Lewtune] (Monte SS)
13.94 @ 98.77, Smokin06impalass - 2.07, 8.94 @ 78.17 [Magnaflow exhaust, tbc, cai, hp tunned, m/t's] (ISS)
13.693 @ 100.65 - 1.976, 8.785 @ 79.36 [Ls6 intake, DT headers, TEP trans w/3.29 gears, HPtuned]
13.14 @ 104.9 - 1.982, 8.467 @ 84.38 [ 1.8 RR, LS6 springs, Corsa exhaust, HP tuned 6250 shifts]
13.19 @ 106, AlabamaGuy - 2.08, 8.58 [Bolt-ons, tune] (MCSS)
13.5 @ 103mph, 2005gxp - 1.9 [Tuned, Doug Thorley Headers, Custom 3" CatBack, Highflow Cat, K&N Intake, SSC Springs]
13.504 @ N/A, CrazyJoe - 2.037, 5.652, 8.689 @ 80.892 [DT Headers, FWI, tune] (GXP)
13.54 @ 103.19, CenTexSS - 2.06, 8.75 [K&N Intake, Magnaflow Catback, 3" DP, Superchips Cortex, DRs] (ISS)
13.595 @ 103.97, Baltsk8er69 - 8.848 @ 81.80 [LS1 intake, catless dp, Flowmaster mufflers, tune]
13.629 @ 106.67, 2005gxp 2.2 60' [DT headers/res/flowmasters/custom tune/K&N Intake/ubend/ssc's] (05 GXP)
13.66 @ 100.65, Super Six - 2.04, 8.88 @ 78.71 [muffler delete, smooth intake elbow, K&N drop in filter, modded stock airbox, flipped motor mount] (GXP)
13.079 @ 102.61, DrOctane - 2.110 60ft. [No headlght] (06 GXP)
13.7 @ 102.7, 05StalledGXP - 2.29, 13.7 @ 102.6 [drop in filter, ubend & res delete, magnaflow mufflers, and stall converter w/ trans tune]
13.748 @ 101.26 JWMayes - 2.036 60ft. 8.869 @ 80.21 [CAI, E-cutout, Lewtune] (06 Monte SS)
13.78 @ 98.260, Battle Ravage - 2.141 60ft. 8.931 @ 80.320 (GXP)
13.82 @101.7, Fubar569 - 2.07 60 ft. [CAI, no headlight, Hogan 3" catless DP into 3" catback Un-tuned] (06 GXP)
13.885 @ 100.35, Heslekrants - 2.229, 9.018 @ 80.43 [K&N Intake, Magnaflow Catback, Stock Tires] (GXP)
13.92 @ 98.2- JP GXP 2.17 60', and 9.03 @ 79.4. DA 1550 on that run.
[CAI, no res, no cat, cutout cracked, no headlight, mild tune]
13.35@101.3 - Weight reduction (3290 lbs). Muffler and res delete with a new tune.
13.93 @ 101.79, MidLifeCrisis - 2.19 [1.8 HS Rockers, Comp Springs/Rods, K&N CAI, Vector HSRK & TCM,3" catless DP](MCSS)
13.94 @ 99.8, Havelegs- 2.12, 9.0 @ 79.1, 13.94 @ 99.8 [K&N Intake, Catted DP, Superchips Cortex]
13.98 @ 98.77, 94SS06GXP- 2.05, 8.97 @ 78.09, 13.98 @ 98.77 [Airbox Mod, No Resonator, Cutout] (GXP)
13.9 @ 96, 2005GXP - 2.12 [K&N, Flowmasters] (GXP)
14.046 @ 100.94, Gorske- 2.287 60ft.[Thrush mufflers, res and cat delete, tune] (ISS)
14.05 @ 100.4, DP 08 GXP - 2.24 [Magnaflow Catback/Cutout/Poly MM/CAI/160*/TBS/STB F&R/3'' DP/XP5243 Atl. Plugs/10.4mm Taylor Wires] (GXP)
14.076 @ 98.46, Dom8755 - 2.08 60ft. 9.057 @ 77.86 [Stock w/no headlight] (06 GXP)
14.124 @ 96.870, CrazyJoe - 2.097 9.071 [stock] (GXP)
14.13 @ 97.44, lostnthenet - 2.05 [stock] (GXP)
FI Cars
12.62@109 2005GXP 1.7 60ft. [Cartuning stage I turbo kit, ported LS4 intake, 3" Catback]
11.49 @ 117, supercatxr7 - 1.784 [Cartuning Turbo Kit |MagnaFlow Exhaust |HS 1.8 rockers | Patriot Gold Valve Springs|Ported intake manifold|Triple Edge Performance Transmission|PI Torque Converter] (MCSS)
11.01 @ 126.69 1.75 60 ft. built engine.
11.99 @ 119.60 SSLEEPY 1.99 60ft. 7.38@93.94 1/8th [Cartuning Turbo kit w/ rear manifold-3" downpipe,Cartuning built trans,PI 3000 stall convertor DR,s] 06 ISS
12.147 @ 120, GXPJAY - [Cartuning Turbo Kit, That's all I know...] (GXP)
12.5 @ 109mph, Rossko85 - 1.8 [E85 Turbo setup, nitto 555r's]
11.29@120mph 08 pimpala ss turbo trans
Old 04-01-2010, 10:16 PM
JDMC5's Avatar
sorry to interject (but you should expect that by now) but maybe you should post mods along with track conditions and what not.
Old 04-01-2010, 10:25 PM
DavidGXP's Avatar
13.98@98.8 Bone stock with a 2.06 60ft.
Old 04-01-2010, 10:37 PM
CenTexSS's Avatar
We should get a sticky for this, and timeslips should only make the list.
And a legend for mods.
CenTexSS
2.08 60 foot
8.75 @ 80.36 1/8th
13.54 @ 103.19
K&N Intake, 3" downpipe, Magnaflow Cat-back, Superchips Cortex, DR's
Old 04-01-2010, 10:58 PM
AlabamaGuy's Avatar
I was thinking about this. If we could get a way to do it without the post getting too crowded I say let's go for it.
Old 04-02-2010, 12:09 PM
havelegs's Avatar
Is this only for track or can you post your results from a timer? For example the Cortex tuner has a timer. Is that valid?
Old 04-02-2010, 01:45 PM
CenTexSS's Avatar
Real times only!
Old 04-02-2010, 03:03 PM
havelegs's Avatar
Originally Posted by CenTexSS
Real times only!
That's fine but I don't know if you can fully discredit the reader false if it connects to the ob2 port, it reads exactly what the computer of the vehicle will read as far as speed sensors and the length. The track here sucks and is always packed, you're lucky to get one run
Old 04-02-2010, 03:37 PM
JP_GXP's Avatar
Like I've said before, my DashHawk told me I ran a 13.0 @ 109 and 0-60'd in 4.5 seconds. It plugged into the OB2 and I don't believe it for a second.
I say post time slips.
EDIT: The closest track to me (that's still open...) only does 1/8 mile now (FTL). Eventually a group of friends and I are going to go to either Arkansas, Baton Rouge, or Dallas.
Old 04-02-2010, 04:00 PM
havelegs's Avatar
Ok no problem. 13 seconds lol..
Old 04-02-2010, 05:16 PM
CenTexSS's Avatar
As mentioned, mine was nearly dead on for a few runs. But any tire spin really throws the accuracy out of the window.
Not to mentioned the track has a controlled environment, and perfectly accurate sensors. I can go find a downhill stretch and get some outstanding numbers with the Cortex lol
Old 04-03-2010, 07:26 AM
crazyjoe's Avatar
60ft 2.097
1/8 9.071 @ 76.848
1/4 14.124 @ 96.870
Bone stock on street tires.
Old 04-03-2010, 09:16 AM
DP 08 GXP's Avatar
60ft 2.24
1/4 14.05 @ 100.4
mods:
Magnaflow Catback/E-Cutout/Poly MM/CAI/160*/TBS/STB F&R/Wrapped X-Over & 3'' DP/Flip Paint/XP5243 Atl. Plugs/10.4mm Taylor Wires
on street tires
Old 04-03-2010, 11:00 AM
Heslekrants's Avatar
Vehicle: 2008 Silver 4 door Grand Prix GXP
Run Date: 4/17/2009
Track: Portland InternationalRaceway
Reaction Time: 0.233
60 foot: 2.229
1/8 mile: 9.018 @ 80.43
1/4 mile: 13.885 @ 100.35
http://www.youtube.com/profile?user=.../4/17W-TJNNhtc
Track/Run Information:
This was with TC on. Still learning how to drive this front driver.
Old 04-04-2010, 03:01 PM
AlabamaGuy's Avatar
Bump. Let's keep this one alive guys
Old 04-08-2010, 06:38 PM
Super six's Avatar
Here is my time slip and pic to go with it... at the Edinburg International Raceway. 13.8 @ 99mph with just a muffler delete as you can see in the pic.
Old 04-08-2010, 06:48 PM
JP_GXP's Avatar
1.9 60' very nice!
Old 04-08-2010, 07:05 PM
Super six's Avatar
Yea that is my best 60ft... it was just good track prep cause my stock tires were less then 50%. I was actually shocked cause the car just dead hooked with not even a sweak. And it was at idle cause I never stall it cause it always spins.
Old 04-08-2010, 07:14 PM
smokin06impala ss's Avatar
2006 impala ss
Track: Edinburg International Racetrack
60' 2.07
1/8 8.94 @ 78.17mph
1/4 mile 13.94 @ 98.77mph
Mods:Magnaflow exhaust, tbc, cai, hp tunned, m/t's
Old 04-08-2010, 10:44 PM
AlabamaGuy's Avatar
Keep 'em coming, gentlemen.
Quick Reply: Track Time Compilation updated 5 MAY 2015
