No Top Speed Limiter on Stock 08 GP GXP?
Howdy all! This is my first post here, however, I've been lurking for some time.
I recently bought a beautiful black 2008 GP GXP used from a dealer in Austin TX. It was a decent compromise over the G8GT that I wanted, and it was a HUGE upgrade from the 99 Regal GS I was coming out of. The only thing I've done to it is put a K&N panel filter in it, and replace the tires with BFG G-Force KDW's (235/50's out back, stock size up front). I absolutely love this car.
I have understood from all I've read, that these cars have a factory speed limiter that shuts them off at 138. Well.....that's not true on mine. Mine apparently does NOT have a speed shut off of any sort, yet the RPM's are still limited to the factory 6K. The disabled traction control still kicks in with the slightest turn of the steering wheel. This has led me to believe that mine still has the factory programming, all except for the speed limiter.
I have a video of the speedometer in this car, accelerating from 80 to 148 mph in 30 seconds flat (Garmin GPS confirmed speed). I used a stop watch multiple times, while watching the video to verify the 30 seconds timeframe. It seems to pull at the exact same rate of speed constantly, which is much different from any other car I've ever owned. Today, I hit 150 in it for the first time in my life in a vehicle with 4 doors. Amazing for a FWD grocery getter.
So is this normal for a basically stock GP GXP?
Thank you for the welcome! The only other modification I have done is remove the front license plate holder. I think it looks much better without it, and I rarely ever get harassed by the locals for it. A friend that's an automotive painter, painted me some "plugs" as he calls them that pop into the factory rivet holes, and the heads sit perfectly flush with the surface of the front fascia.
Here's a few cell phone pics, and the vids as well.
I have still been learning how to master the Tap-Shift. In this vid, if you watch the tach, you can see where I drop it back to 2nd at 80, bounce it off the rev limiter for a sec as I shift to 3rd @ 100 a little late, then hold it in 3rd through the rest of the range. You can also see the tach drop way down as I for whatever reason, "tapped" it into 4th as I hit 148.
This one is from today where I hit 150. BTW, this was done on a newly opened section of tollway, that has light traffic, concrete barricades on both sides, 3 lanes wide and only one clearly visible entrance for a few failry straight miles. Yes, I understand the risks of driving at that speed, and it is NOT something I will make a habit of.
I bought my 08 GXP brand new a 2 years ago and did 153mph in it with the factory tune and no mods. It probably would have gone faster, but I had to let off due to... not traffic.
I have an 09 Impala and on my stock tune mine was set to 165mph from the factory. I thought my buddy who was doing my tune was pulling my leg and then he showed me on his laptop screen. I just left it there cause thats damn fast enough for me.
