Anybody have oil pump failures? TSB
Old 05-28-2010, 09:22 PM
DavidGXP's Avatar
Default Anybody have oil pump failures? TSB
I was just fooling around on the web and found this.
#PIP4158: Low Oil Pressure Or Siezed Oil Pump - keywords 07 08 5.3 6.0 6.2 engine knock L76 L92 LC9 LH6 LS4 noise tick - (Jun 25, 2007)
Subject: Low Oil Pressure or Seized Oil Pump
Models: 2007-2008 Cadillac Escalade
2007-2008 Avalanche, Chevrolet Express, Silverado, Suburban, Tahoe, Trailblazer
2007-2008 GMC Savana, Sierra, Yukon
Vehicles equipped with aluminum block engines RPO codes L76 L92 LC9 LH6 LS4
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
The customer concern may be low oil pressure, no oil pressure, or engine noise.
Recommendation/Instructions:
Complete the current diagnostic for any diagnostic trouble codes or symptoms found. If a customer concern of engine noise has been verified, and low oil pressure has been found, replace the oil pump, flush the oil cooler lines, clean the oil pan, and change the oil and filter.
It is possible for the oil pump to seize, and start to work again when the engine cools down. Evaluate all customer concerns of low oil pressure closely, and replace oil pumps as necessary.
My engine seems fine. I do get the ticks and a weird rattling noise when in four banger mode, when cold. Just something else to worry about
Old 05-29-2010, 01:51 PM
Sittingmongoose's Avatar
THats not our car. None of those cars have our engine. Our oil pump is upgraded over the ls1 oil pump and is pretty good. I personally did have mine fail but that is because i threw a rod bearing and it sent pieces of metal through the oil system.
Old 05-29-2010, 02:12 PM
DavidGXP's Avatar
The LS4 is mentioned above, just not the 05-06 models.
Old 05-29-2010, 02:23 PM
neilownz's Avatar
Could be just the 07+ LS4.
Old 05-29-2010, 06:06 PM
nevermind i reread it
Quick Reply: Anybody have oil pump failures? TSB
