What fuel treatment do you use?
Old 06-04-2010, 05:58 PM
jabronie78's Avatar
Default What fuel treatment do you use?
I use Lucas bout every month or so. Doubt that it even does anything. Do you guys use anything and if so what
Old 06-04-2010, 06:41 PM
Mgpeagle's Avatar
I use 2 stroke marine oil. It has to be twc3 rated though. It is blue. I use 1 oz. for every 5 gallons of gas. I run no cat so this solves the exhaust odor, keeps the top end lubricated and my ringpacks clean. It raises the btu content of the gas so it gets a better burn too. I have been running this for about 8 months now and only see benefits. I also get a bit better gas milage using this by .2 mpg.
-Mike
Old 06-04-2010, 06:47 PM
mike690003's Avatar
me too! I run it in my 2000 SS. The idle is even a little smoother!
Old 06-04-2010, 06:49 PM
Mgpeagle's Avatar
Thanks dude. I fixed it... lol... I agree with the idle too. It is smoother.
-Mike
Old 06-04-2010, 06:53 PM
mike690003's Avatar
No prob
The SuperTech one from Wal-Mart works just as fine as the Synthetic one I spent $26 on. So no need to go big.
Old 06-04-2010, 06:59 PM
Mgpeagle's Avatar
I usually use the Pennzoil or Havoline from Advanced Auto. It's either 4.69 or 5.69 per quart and a quart lasts 2 months or so for me. Plus, it is much, much cheaper than all of the other products "supposidly made" to do the same.
Do you use it in the 07?
-Mike
Old 06-04-2010, 08:00 PM
GXP25's Avatar
Techron whenever I can't fill up at a Chevron or Exxon. And I only use the stuff once every 3 months or so.
I tried SeaFoam once and it seemed to do a "better" job. I run 87 octane pretty much all of time and I guess it's all relative. If you're running 93 or 91, I wouldn't be too worried with fuel treatments.
YMMV
Old 06-04-2010, 08:39 PM
mike690003's Avatar
I don't run it in the 07. I should, but due to the fact I don't drive it often, I just use it in the DD.
Old 06-04-2010, 11:35 PM
neilownz's Avatar
seafoam
Old 06-04-2010, 11:38 PM
DavidGXP's Avatar
Seafoam in the crankcase 1 week before oil change and the rest of the can through the PB vacuum hose with the engine running. In the tank I use seafoam after each oil change. My tb is dirty and my intake is soaked with oil. I just added a qt with 50% oil life.
Old 06-06-2010, 10:11 AM
LS1 Racing's Avatar
I had no idea so many people used fuel treatment. I was taught that if you quality fuel (and good oil), you don't need that stuff.
I'm not knocking anyone who does use additives, just sharing what I've learned.
Anyone have links to independent tests of these things? I am open-minded about trying stuff if it will make the car run better.
Old 06-06-2010, 10:56 AM
Mgpeagle's Avatar
The best thing to do is give it a try. I was very skeptical at first too but the car seemed to like the stuff so I just keep adding it in. I use 1 oz. for every 5 gallons of gas. I use a turkey baster to put the stuff in the gas tank. It does work well. Plus it's very cheap.
-Mike
Old 06-06-2010, 01:46 PM
LS1 Racing's Avatar
-Mike
I'll do some research on this and maybe give it a shot.
Old 06-06-2010, 03:26 PM
LS1Tech Sponsor
06MonteSS's Avatar
yep... use the 2-stroke tc-w3 in my car too... and the wifes... for over a year now... good stuff!
I use the Amsoil.... http://twincamlubricants.wboil.com/storefront/hpi.html
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old 06-06-2010, 03:29 PM
jabronie78's Avatar
Do you guys use it at every fill up?
Old 06-06-2010, 03:37 PM
rquinn19's Avatar
As if gas isn't high enough? Hope not
Old 06-06-2010, 04:04 PM
LS1Tech Sponsor
06MonteSS's Avatar
yep... I do...
I buy the 1 gallon jug... it lasts a while, even with using 1 oz per every 4 or 5 gallons of gas, in both vehicles...
__________________
Old 06-06-2010, 04:31 PM
Mgpeagle's Avatar
Lew,
Remeber that HUGE post on ls1.com? It was an old guy that worked 50 yrs. for Chevron that started the thread. It had 100 plus pages on it. I can't find it. He was the one that swayed my opinion and he did real world testing on it for over 100,000 plus miles. Do you have a link to it?
-Mike
jabronie78's Avatar
I'm going try it out, thanks for the info.
Mgpeagle's Avatar
I use it at every fill up too. 3 to 4 oz per tank.
-Mike
Quick Reply: What fuel treatment do you use?
