Trans Go Shift Kit Installed - First Impressions
Old 07-29-2010, 03:02 PM
texasGXP08's Avatar
Default Trans Go Shift Kit Installed - First Impressions
Today I finally worked myself up to install my trans go shift kit in the car today. I also replaced the pan gasket and fluid filter while I was in there. I would like to thank BADDLS1SS for his how-to sticky. It can be found at https://ls1tech.com/forums/ls4-front...tch-movie.html. The process was not bad at all, here are some pictures.
The Goods
Oh ****, here we go!
Tranny fluid looked pretty beat for only 27,000 miles
All cleaned up!
****! So while pulling the filter out, I wiggled it a little to much and broke the neck off of the filter and it was still in the tranny.
Thankfully, my trusty vice grips saved the day!
Here is a shot of the accumulator coming out
Here is the disassembled accumulator next to the new springs and spacers
This is a shot of everything buttoned up and my B&M Tranny Drain Plug Kit installed.
The Drive:
Ok this is what everyone wants to hear. This shift kit is not aggressive at all. I had a b&m stage 2 shift kit in my 1989 Formula Firebird, when I was in high school, and that thing was excessive. It would chirp the tires on any shift over 2500 rpms. The transgo is nothing like that. However I am not disappointed at all. The up-shifts have a firmer, positive feel to them. They are also noticeably faster, but I don't see it ripping the tires. The downshifts are MUCH better! They are instantaneous now! Again, not aggressive shifts, but incredibly snappy! This is how the car should have came from the factory.
Would I recommend this? Yes, as long as you are not looking for ripping the tires on the shifts, than you will notice faster shifts and a more positive feel during shifting. For the $65 it costs, I am satisfied.
Old 07-29-2010, 03:31 PM
DieselPump's Avatar
Agreed, this shift kit is great.
I experience exactly what you've mentioned.
Old 07-29-2010, 03:59 PM
tmichelena's Avatar
Awesome! I may have just been convinced. Will this reduce transmission wear? Do you notice decreased temps?
Where did you get the kit at?
Thanks!
Tom
Old 07-29-2010, 04:49 PM
Mgpeagle's Avatar
Raise the line pressure too and you'll get a much firmer shift. Mine shifts pretty fast from 1st to 2nd. You certainly can feel it. I have both the transgo kit and the line pressure raised.
-Mike
Old 07-29-2010, 05:44 PM
lb06mcss's Avatar
Where did you get this kit for $50?
Old 07-29-2010, 10:18 PM
texasGXP08's Avatar
I got the kit from Triple Edge Performance. Also, it is $65 not $50, I was mistaken.
Old 07-29-2010, 10:19 PM
texasGXP08's Avatar
Thanks!
Tom
I have not driven enough to notice decreased temperatures, but it is advertised as prolonging transmission life. I cannot explain how since I am not an expert at trannys, but the car drives great with it!
Old 07-29-2010, 10:44 PM
DavidGXP's Avatar
Sometimes mine bangs gears but most of the time its stupid soft even with tuning. I talked to Dave at TEP and he said that the second gear clutch pack needs a extra clutch in order to get some neck snapping shifts. He also does a few other tricks here and there.
Downshifts are killer though... I could chirp the tires when punching it going 35mph in high gear. My trans fluid at 30k was much worse looking and I'm glade, I changed it when I did! This shift kit is a great upgrade to add while doing a filter and fluid change.
Old 07-30-2010, 12:02 AM
Z28 Autobot's Avatar
ok anyone in MA want to do mine?? lol
Old 07-30-2010, 11:58 AM
tmichelena's Avatar
Does anyone know if this is a trans go kit?
Thanks,
Tom
http://www.zzperformance.com/grand_p...=570&catid=105
Old 07-30-2010, 01:11 PM
texasGXP08's Avatar
Thanks,
Tom
ZZP makes their own shift kit. I could not explain the differences to you between TransGo and ZZP (if any). The only reason I went with transgo is that Dave at TEP (Triple Edge Performance) sells and recommends them. He has a good reputation here, hence my decision.
Old 07-30-2010, 01:34 PM
Mgpeagle's Avatar
Dave,
It's easy... Only takes at most 2 hours or so. See you on Aug. 8th.
-Mike
Old 02-10-2011, 04:43 PM
Emoney81's Avatar
Was it necessary to change the accumulator gasket or did you just reuse the old one?
Old 02-10-2011, 05:40 PM
texasGXP08's Avatar
You can reuse the old one and save $30.
Old 02-10-2011, 05:48 PM
LS1 Racing's Avatar
I have the same kit that was installed at the same time as the TEP valve body, and on the same settings as yours. The difference is very clear, though I noticed a much quicker 2-3 shift, as I had the clearance reduced in my 2-3 clutch pack.
The reason the shifts aren't aggressive is because the loose converter in our cars tends to deaden the "jolt" that you'd otherwise get with a normal converter.
If I had to do it again, I would set it to the race setting, since I won't be increasing the line pressure anytime soon.
Old 02-10-2011, 07:28 PM
ImpSS07's Avatar
Damn, would you guys mind not making me want to spend more money!!!!
Texas, I'm glad your happy with the results and I think I'm gonna have to pull the trigger on this one too!
Old 02-10-2011, 07:46 PM
texasGXP08's Avatar
You really should. The cars should have came like this. It is very easy, and would make a good afternoon project once it gets warmer out.
Old 02-10-2011, 10:33 PM
Emoney81's Avatar
Sounds good to me. Also, did the kit come with directions and did it tell you which springs to use?
Old 02-10-2011, 10:47 PM
evil 5.3's Avatar
Not meaning to jack the thread but what is the difference between this and doing it threw a tune
Old 02-11-2011, 07:24 AM
texasGXP08's Avatar
Yes. It came with an instruction sheet that is illustrated. Only the first page is relevant. There is a lot of non-shift kit related things in there, I guess because the maker assumes shop personnel will be reading it. There is a picture on the springs sitting on the instruction sheet in my first post. It seem intimidating but it you have a socket set and ratchet, it is not very hard. Messy maybe, but not hard.
Quick Reply: Trans Go Shift Kit Installed - First Impressions
