MSD Igntion - LS1TECH
MSD Igntion
Thread Tools Search this Thread
Old 09-26-2010, 12:34 AM   #1
Default MSD Igntion
Hey guys,
Anybody here run the MSD ignition coil package and have any feedback? I know Mel does...not sure it's worth the $669?
Thanks,
Tom
tmichelena is offline   Reply With Quote
Old 09-26-2010, 12:47 AM   #2
Quote:
Originally Posted by tmichelena View Post
Hey guys,
Thanks,
Tom
I've gone back and forth with this to, but i ended up going against it. While G.M. did cut a few corners in making these cars, one area they did not skimp on was the ignition system. To the best of my knowledge its actually a pretty good system stock and messing with it doesn't really give any real gains. Certainly not ones that would justify spending that sort of cash IMHO.
D J Real is offline   Reply With Quote
Old 09-26-2010, 01:30 AM   #3
dcrews's Avatar
Search around here for the truck coil upgrade. Seems to be the way to go if you wanted to upgrade
dcrews is offline   Reply With Quote
Old 09-26-2010, 01:39 AM   #4
neilownz's Avatar
Accel makes some too. Waste of money imho.
neilownz is offline   Reply With Quote
Old 09-26-2010, 07:46 AM   #5
Mels SS's Avatar
I just have the MSD ignition plug wires the stock coils are hot enough. The wires are the issues and a lot cheaper than than coils and the truck coil are a waste there just as hot.
Mels SS is offline   Reply With Quote
Old 09-26-2010, 11:33 AM   #6
LS1Tech Platinum Sponsor
06MonteSS's Avatar
yeah... don't do it man...
you'll end up introducing problems when you don't have any to begin with... don't need the MSD stuff at all.... stock with stockers!!
have seen a lotta people have issues after they installed the MSD stuff...
06MonteSS is offline   Reply With Quote
Old 09-26-2010, 12:17 PM   #7
Nemesis350's Avatar
Sorry, i have nothing against msd, but everyone i know that has boughten their coils packs for the ls have had them fail at some point.
If you want anything other than stock (which aren't bad at all) you should find the round truck coils deemed D585. They're said to have better output top end, are the preferred choice of forced induction setups, and usually don't cost anymore than $150 for a full set on brackets with wiring harness.
If you want anymore detailed info, put d585 in the search, and read up on the plentiful info.
Nemesis350 is offline   Reply With Quote
Tags
2000, carlo, ignition, monte, problems
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
