O/T: This '00 GTP worth $500? - LS1TECH
Thread Tools Search this Thread
Old 11-23-2010, 03:56 PM   #1
Question O/T: This '00 GTP worth $500?
Quote:
The Good, It is bone stock. Has a clear LA title A/c and heater work Doesn't leak oil Sunroof works and doesn't leak. The Bad, Car will only run for about 20 minutes before running hot, they were told it was a blown head gasket, but after changing it, it still ran hot. The only window that works is the passenger front, the other 3 are either off track or the track is broken. The driver side fender is dented in due to someone backing into the car in the driveway about a month ago. They were told it bent the strut too.
Thoughts?
JP_GXP is offline   Reply With Quote
Old 11-23-2010, 04:04 PM   #2
LS1Tech Platinum Sponsor
Sales2@Texas-speed's Avatar
For $500 I'd buy it, fix the overheating issue and windows, and sell it for $4-5K easily (depending on mileage and such obviously).
Sales2@Texas-speed is online now   Reply With Quote
Old 11-23-2010, 05:09 PM   #3
gxp-miller-gxp's Avatar
haha i was thinking the same thing jp, i just dont have 500 dollars. its a nice car besides the fender/strut/overheating. and im sure the windows are just off track considering its all three of them.
gxp-miller-gxp is offline   Reply With Quote
Old 11-23-2010, 07:14 PM   #4
107,xxx miles. I planned on dailying it, while the GXP can be properly broken down and prepped.
Maybe even find another LS4.
Old 11-23-2010, 07:18 PM   #5
LS1 Racing's Avatar
Quote:
Originally Posted by JP_GXP View Post
Thoughts?
I assume they changed both head gaskets, right? If that didn't solve the problem, and I assume they already eliminated the radiator/water pump/t-stat as problems, then it could be a cracked head or maybe even the block. Never heard of a 3800 doing that, but I suppose it's possible.
Still, even $500 for a decent GTP, even if it wasn't running, is not a bad deal.
LS1 Racing is offline   Reply With Quote
Old 11-23-2010, 07:40 PM   #6
Well, if little GXP there doesn't get it and tax time is good to me, I'll see what I can do with it.
Old 11-23-2010, 07:45 PM   #7
lmfao little gxp hahahaha.
u mean put an ls4 engine in it?
Old 11-23-2010, 07:46 PM   #8
Well, you're younger and littler than me. And if the L67's toast, I'd like to.
Old 11-23-2010, 08:45 PM   #9
Mgpeagle's Avatar
I have a 97 modded GTP and I think 500.00 is a good deal. Did they change the thermostat? I know it's a stretch but ya never know. Also, on those cars there is coolant that runs into the throttle body. The gasket that is between the tb and intake deteriorates and lets coolant into the intake. I replaced mine with a ZZP rubber gasket that is reuseable and covers the coolant hole in the tb. Cooler air baby...and no more coolant in the intake. May want to check that if you do purchase it.
-Mike
Mgpeagle is offline   Reply With Quote
Old 11-23-2010, 08:57 PM   #10
01FbTaWs6's Avatar
did everyone miss that part? if it bent the strut, it was a little more then just "backed into"
01FbTaWs6 is offline   Reply With Quote
Old 11-23-2010, 08:57 PM   #11
01FbTaWs6's Avatar
Old 11-23-2010, 09:10 PM   #12
yeah but the picture of the fender damaged doesnt look to terribly bad, and he said it drives fine.
Old 11-23-2010, 09:14 PM   #13
Flip's Avatar
I paid 500 for the silver GTP ( 105k ) with a blown head gasket.. & 500 for the 02 40TH GTP with 32k on it.. Then went crazy..
The car..
parts car
Its almost done..
Flip is offline   Reply With Quote
Old 11-23-2010, 09:38 PM   #14
WOW, NICE!
I'm not worried about it being plowed over, I don't want them to fix it then ask for more, I wanna get it and fix it myself.
Old 11-23-2010, 09:50 PM   #15
if u put the ls4 in wouldnt u need larger radiator? and how hard would it be to connect it like with pcm and all that? like would that car's dic and everything easily connect to the ls4?
Old 11-23-2010, 09:58 PM   #16
I'm assuming it would be a massive PITA, that's why I said I'd like to. I don't have the patience or know-how to do that swap. I'll probably let you get that one and I get that other car I've been looking at.
It would be nice to have a HUD in 2 cars though...
Old 11-23-2010, 09:59 PM   #17
lol im not even sure if i can get it, have to get the money first. lol
Old 11-23-2010, 10:01 PM   #18
He'll be sitting on it for a while. Unless they just scrap it... Speaking of, there's a GTP in a junkyard down the road from my house if either one of us gets it.
Old 11-23-2010, 10:37 PM   #19
Mels SS's Avatar
Get the GP I would
Mels SS is offline   Reply With Quote
Old 11-24-2010, 11:31 AM   #20
how banged up is the one in the scrap yard? and is has a good left fender and strut then awesome.
Tags
2000, 2006, arp, carlo, changing, grand, gtp, leak, monte, mufflers, oil, pontiac, prix, pump, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
