4T65E-HD Delayed engagement fix
Slip and catch is due to seals not holding pressure consistently and adequately. This is because the factory seals shrink with age and mileage.
I recommend you contact Dave @ Triple Edge Performance before increasing your line pressure, as you could accelerate your problem.
My 06 Impala LTZ had the occassional slip when stopped at a light and then accelerating. I added the transgo shift kit, but it still occurred occasionally. Next step was to pull the side cover and replace the pressure solenoid which is generally the problem and requires a bit of work to do. Instead of doing that I had Cartuning slightly increase the trans pressure and also shift times. Problem has never occurred since then. Been about 6000 miles or so and no more issues.
Can it be tuned to only be increased at IDLE RPM and car speed is at 0mph?
Why did they increase shift times?
Can you tell me who you worked with over there? Did they give you a list of parameters they adjusted, and the before and after values?
Thank you!
Brian
I don't have HP tuners now but this would make me want to buy it. I'd love to fine tune it for just enough pressure to eliminate the slip, but as low as possible still.
So there's no separate pressure setting depending on speed? How about depending on what gear you're in?
Moderator
That is what I was thinking, a very slight increase in pressure.
Thank you!
Brian
Thank you!
Brian
.50 sec less till you like it.
You increase pressure for better holding of power and less wear
3-5% each time till it feels just firm enough.
In hptuners there are aldot of trans tables to adjust but the end result is awesome. Any competent tuner can get it done
I'm still suffering with the random occasional slip-then-catch off line.
Boattail455 - is your transmission still working correctly off the line since you upgraded your magnets to pull more shavings out of the fluid? You are not the only person to find that upgrading their magnets fixed this issue, so I think I am going to give it a shot. It's cheap and easy compared to adding line pressure. You didn't use any kind of trans cleaning additive first, right? The other account I read, the owner put in 8 oz of Seafoam Trans cleaner before the pan drop.
I was considering buying HP Tuners and slightly bumping line pressures, but I couldn't get any clear help on the forums at hptuners.com. Wasn't clear to me whether I'd want to adjust the force motor current table slightly lower... or line pressure table slightly higher. Seems like people do either/both. And nobody could tell me how to limit the line pressure increase to 0mph at idle RPM. Because I never have a slip once moving, even slowly, and I'd rather not increase the pressure across the board if I don't HAVE TO. But If I have to, I probably would... like I said my questions were never answered there.
Thanks all!
Brian
Thanks all!
Brian
#32
Thanks all!
Brian
Thanks all!
Brian
https://ls1tech.com/forums/ls4-perfo...rans-tune.html
#33
Thanks rottonj, that's good to know.
In that thread I notice that one person suggested the Seafoam helped you by thickening things up, causing less blow-by on some seal. You corrected him in that Lucas is thick, but Seafoam is very thin, a cleaner.
On that train of thought, I just wanted to mention that I did give Lucas a shot. I put in about 1/3 of a bottle a year ago just to see if it happened more often, the same, or less. I found no difference, not even a slight reduction in how often it happens. So I personally no longer believe the issue is due to seal blow-by. I also don't really think its as simple as a worn forward band. My problems started around 60,000 miles and the car has been driven very very gently and I only have 200hp behind my 4T65-E.
At this point it's only a hunch, but I think the theory that the PCS gets contaminated due to being magnetic is a strong possibility. I have neodymium magnets ready to go. I am considering putting 4-5 of them in the bottom of the pan since I bought a 10 pack. I don't see how too many would be harmful? Along with fluid and filter again.
#35
#36
Actually the bottle is 24 ounces, not a quart.
And I went back through my notes and I was wrong.... I didn't do 1/3 of a bottle, I did 1/2 of it, 12 ounces.
It's very thick and I left it in there for months, before I did my next pan drop. I was worried that all that extra viscosity wasn't good for the trans, especially if it didn't help my symptoms. I am pretty sure if it was going to thicken the fluid enough to stop some seal leak, I would have noticed at least a marginal improvement. At least a reduction in how often it occurs.
My test run was long enough I am 100% confident it did nothing at all. Which further backs my suspicion it's not a seal, nor is it a clutch/forward band. Not in MY case anyway, I am not speaking for all 4T65E owners obviously. It's quite possible we have similar symptoms with different causes.
I will attach a few magnets to the outside of my pan tonight and test for a couple weeks, then report back.
Thanks for your help and tips!!!
#37
#38
Over 15000 miles now since bumping up pressure and shift times with hp tuners and not a single slip.
No problem. You are right, its more than a quart. I added it first so I forgot that. Try the Seafoam treatment before changing the fluid and filter. I noticed a difference for the better in the way the transmission was shifting within 50 miles, it really was amazing as I was hopeful but not really expecting much.
