Old 04-26-2016, 01:29 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Tranmission Guides
Print Wikipost
LS4 Transmission Problem Thread (4T65-HD); Current Total Inside
Old 01-03-2011, 08:14 PM
Brian396's Avatar
Started having problems around 63,000 miles. Shifting at WOT comeing out of 1st gear she would free wheel for a second then, it would feel like a neutral drop into 2nd gear. I have no idea how the input shaft didn’t break? Under normal driving conditions shifts fine. TEP in the spring. I don’t know if I should be added to list, seeing as I’ve got the turbo?
Old 01-03-2011, 08:19 PM
chaman's Avatar
This is ridiculous, my God! What they used to make these transmissions....
I love how some say' "Im on my 14th tranny but love the car!!" WHAAT!!?
Old 01-03-2011, 08:20 PM
LS1 Racing's Avatar
Did you have any problems pre-turbo?
Old 01-03-2011, 08:26 PM
Brian396's Avatar
Nope. Had it on there for about 1 1/2 years and 20,000 miles? Worked like a champ till 2 months ago.
Old 01-03-2011, 08:42 PM
jrhartman's Avatar
fwiw: the trans in my car that is currently having issues is trans #2 (only ~42k miles on this one)....the original was replaced by the the previous owner at ~66k miles.
Old 01-03-2011, 09:10 PM
LS1Tech Sponsor
06MonteSS's Avatar
I've owned my car since brand new.. I special ordered it when I bought it... and I made it to 100,000 miles on my stock original tranny...
I'm now on my replacement GM SERTA tranny, and am at just about 102,000 miles...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old 01-03-2011, 09:26 PM
LS1 Racing's Avatar
It wouldn't be unreasonable to count yours, however, it could be argued that the turbo was to blame. I'll make a note in post #1 about your mitigating circumstances!
I'm counting multiple failures in the same car as one, as it would be too hard to sort and know who else has more than one. I know JP_GXP and are in the category, but I don't how many others are.
And you probably have gone the farthest before having a failure!
Old 01-03-2011, 09:31 PM
JWMayes's Avatar
Lol, you can add me to both lists. Hahaha. I know my trans has been rebuilt before, but that was before I got the car. But as of now, its been giving my quite a bit of problems.
Clunking, Hard Shifting, RPM up an down while in cruise, grinding, in and out of gear, just to name a few. I talked to my the trans guy my dad knows, and hes pretty good, but he said until the car starts throwing codes, or gets a lot worse, theres not much that can be done. Even though its a list of things happening, they still seem to be very miniscule, and don't happen all the time.
Old 01-03-2011, 09:46 PM
LS1 Racing's Avatar
Added you to the rebuild/replace list.
Old 01-03-2011, 10:22 PM
CenTexSS's Avatar
LS1 Racing for the second moderator for our section.
Old 01-03-2011, 10:41 PM
AlabamaGuy's Avatar
I would tend to agree.
Old 01-03-2011, 10:49 PM
  #32
LS1 Racing's Avatar
Thanks, Man. I'm afraid I've probably pissed off way too many people to get that job! I just want to help shed some light on this problem and see just how widespread it is.
Old 01-03-2011, 11:11 PM
  #33
LS1Tech Sponsor
06MonteSS's Avatar
LS1 Racing for President!!! err, Moderator!!!
__________________
Old 01-03-2011, 11:13 PM
  #34
LS1Tech Sponsor
06MonteSS's Avatar
hehe... yeah, and I don't baby my car either.. never have....
no, I've never been to a track... but, I don't drive like a grandma either...
whenever I have enough room in front of me, I'm ON IT!!
__________________
Old 01-03-2011, 11:23 PM
  #35
gxp-miller-gxp's Avatar
help me out here
so when i park in my driveway ( decent incline) , about every other day or two when i start the car up and try and shift out of park it is extremely hard to, like i can but it defiently takes force, like my gf couldnt back car up for me one day because of it. but once i get it in the gear it is perfectly fine. is this a serious issue?? and did anyone else experience this?
Old 01-03-2011, 11:29 PM
  #36
LS1 Racing's Avatar
Originally Posted by gxp-miller-gxp
help me out here
Sounds like the park pawl is getting torque locked. Do you use the e-brake when you park in the driveway? If you do and are having this problem, you probably need to get the cable adjusted so it will hold.
Old 01-03-2011, 11:33 PM
  #37
yes i always use the ebrake, i push the ebrake in then i put it in park before i get out
Old 01-03-2011, 11:40 PM
  #38
LS1 Racing's Avatar
Then I would definitely check the adjustment of the e-brake cable. You're probably not getting much bite, and it only a takes a slight rollback to make it difficult to move out of park.
Old 01-04-2011, 05:49 AM
  #39
evil 5.3's Avatar
I get what you are saying good job ls1 racing
Old 01-04-2011, 09:28 AM
  #40
JP07GXP's Avatar
I had a shudder down shifting into first with the paddles. I used Lucas oil tranny additive and I don't know if it just stopped on its own or if the additive helped out. I just got a shift kit from ZZP and I wanna throw it in but I'm now wondering if thats a good idea. I'm thinking I should just leave well enough alone. I am also gonna grab a cooler before too long and throw that on too. Any thoughts on that?
Quick Reply: LS4 Transmission Problem Thread (4T65-HD); Current Total Inside
